New Tazer DT firmware beta
Eighty
Moderator / Dream Killer
Shows up on the programming utility now, but not working yet.
Dewey
WI
I’ll let you guys test when available. I just installed my Tazer with the last update and working fine so far. Don’t wanna tempt fate.😆
Dewey
WI
I posted this in the other Tazer thread as well but thought it my apply here more due to it concerning this latest firmware.
I unmarried and removed my Tazer for now. All kinds of weird stuff going on. Doesn’t renember Stop/Start off setting, fog light setting, Kill3Honk setting and when I use either my left or right turn signal the puddle light on my drivers side mirror only turns on for about 5 seconds AFTER the signal is off. Also my Blind Spot Detection quit working.
Everything seems normal now after unmarry and removing the Tazer.
Didn’t have any issues with the previous firmware. This new one released on Monday seems to be an issue. I knew I should have waited.
Is it possible to go back to the previous firmware before the Monday release? I’m sure it’s possible but figured I better ask first before trying.
Eighty
Version 18.1.8 is out, I upgraded my Tazer yesterday (y)
There are so many Tazer threads, I’ve lost track.
18.1.8 came out on 11/21. It fixes the Amber DRL dropout issue, but I believe all the other bug fixes are still being addressed. I’ve heard “early December” for the next update.
ballaz
2021 Ram limited. Had to downgrade software on my Tazer from 1.8 to 1.6 to get auto start stop to work correctly.
Carlos.33193
Seems mine doesn't work either. 2020 1500 limited. I might have to downgrade.
ballaz
Also, it did not work with 1.7 either. Only 1.6. hope that's saves you a step
Carlos.33193
Contacted their support and they told me it was a bug that is being worked on.. in the mean time I downgraded to 18.1.6 as auto start/stop is one of the main reasons I got the tazer.
Carlos.33193
Version 18.2.4 is released, anyone try it yet? It has a lot of new features. Any feedback?
I posted about it yesterday in a different thread cause I couldn't find this one. The search function leaves a lot to be desired.
I enabled the killbyfob feature. Hopefully won't have to ever see if it works.
Carlos.33193
I just enabled that one too.. if I understood correctly you don't need to have a pin enabled for it to work. Does that mean I don't need the pin set? Or I should I set a pin, but then leave it disabled? What are your thoughts on that one.
I did not want a pin set because my wife would hate it and I would get calls everytime she drove the truck. So I am just using the killfob only with pedalkill. I have noticed when I lock the truck now with the fob, the doors will all lock, then a couple seconds later it honks the horn. I imagine that just is an indication the security function is enabled.
Main reason I updated was more because it said it fixed an issue with the brake lights when using the brake hold function, which I enjoy using.
