Upfitter Switches
@ Csjumper... that menu may show up on the radio.. I think that's were you're going find the settings... I think at least ;)
-=FM45=-
-=FM45=-
With our wrangler that has the factory installed switches there is an option on UConnect to select what you want the switches to do.
I won’t say no outright.
I’ll have to order the parts and wires …..
Then I figure a couple hours to make it look good, but I wasn’t going to bother till I found an aux switch panel …..
I’ll check that availability of that part number on Monday and let you know.
How’s that sound?
-=FM45=-
Huh. Wonder what it would be under or if it’s an option itself. Anyone know how to get it to show. Didn’t use tazer. I used alpha
How’s that sound?
Yeah the relay setup is easy. The oem plugs were what I was interested in. But getting that relay setup second hand I have it now. Just wanted to warn people on 4WHEEL electronics since they are not caring to make money I guess.
What relay setup did you get?
Man. After playing around I was able to get the aux switch options to show. So I made all the changes in alpha. I have a tazer in line I use for my bypass. So when going through settings it showed 6swt for aux buttons but weren’t showing. So changed from off to back to 6swt. And did a full reboot. After the reboot the aux options Started showing. Check it out .
What year is your Ram?
68476024AB
Now the down news. I was trying to reach out to 4WHEELelectronics.com and Craig seems to of stopped answering any type of communications. I tried to call his phone number and just goes straight to voicemail. I tried to email him and nothing. I also tried to chat with him and nothing. And when I say nothing I mean he hasn’t answered once on the 7 emails, 10 different chats, 15 calls and 10 voicemails over the past couple months.
Maybe someone knows how to get ahold of him but man a good idea but this company seems to really be lacking even to say hey I can’t get materials to make these or something.
Just wanted to give you a heads up, as you may need to find a different relay, or even the oem type relay setup. Other than the switch I’m told that may work too
Hi There,
Sorry to bother you.
Do I understand your previous comments where you mentioned that you have been waiting for Switch #68376640AE BUT was able to use 68476024AB instead?
I have ALSO been waiting on that first switch for months and it would be awesome to have an alternative.
Thanks so much!!!
Hi There,
Thanks so much!!!
Yes they seem to be the same switch. I can’t figure out why no one is saying if the part was superceeded or not, but yes I originally was told the ae one was the part. Then with talking with other people found the ab one and it was in stock. Cheapest place I found was worldpartsdirect.com
Awesome, thanks very much!!
There are different part numbers for later trucks as there was a slight revision to style. The part number may be the revised version which may look slightly different.
I know in the HD's, the panels went from glossy to matte.
