ferraiolo1
Got it some more garage friends.
I was unaware that they had made a Destroyer Gray Built to Serve! I have a 2019 Destroyer Gray wide body Challenger!Car show today. Have both my truck here. It's the last car show of the season and the local Mopar clubs Mopar only show. Could have asked for a better day at the end of Oct. 80s and clear sky. View attachment 141911 View attachment 141912 View attachment 141913
Yes, Ram calls it Ceramic Gray though. Was one of the Navy colors.I was unaware that they had made a Destroyer Gray Built to Serve! I have a 2019 Destroyer Gray wide body Challenger!
Yours wrap further down than any I tried to find and found. Can you please post a link to that exact sill cover?
Hong HT Car Accessories Carbon Fiber Door Sill Scuff Protector Auto Door Entry Guard Scratch Shield Car Door Sill Sticker for Dodge Ram 1500 2012-2022 Auto Accessories (1500, White) https://a.co/d/ejx1A2tYours wrap further down than any I tried to find and found. Can you please post a link to that exact sill cover?
I had some grease in my passenger front wheel when I took them off to get the tires swapped over. I haven't checked again yet to see if it came back. I'll have to go take a look I guess.I took mine to the dealer today with a little over 1300 miles on it for a warranty repair. They replaced the right side CV axle after the boot leaked grease everywhere. Glad that's fixed!
Thanks @Mopar_maxiHong HT Car Accessories Carbon Fiber Door Sill Scuff Protector Auto Door Entry Guard Scratch Shield Car Door Sill Sticker for Dodge Ram 1500 2012-2022 Auto Accessories (1500, White) https://a.co/d/ejx1A2t
I've been using the SRT filter since my first oil change two years ago. No issues what so ever. Would rather have the slight inconvenience of getting the larger filter in and out in exchange for better filtration.Did an oil change, used the SRT filter (5038041AA). After installing I understand why RAM switched to the smaller filter when they started using electric power steering. There was a half inch or less gap between the power steering and the filter. That doesn't leave much wiggle room, engine movement in an extreme case might allow the filter to hit the power steering causing a puncture. Long story short the SRT filter was removed and put on a WIX 57060 XP
nice workshopI finished the siding on my new workshop and figured I'd spoil my truck for a night and actually park it inside for a change. Once I get the inside done and move in all my tools, she'll get banished to the covered area.
She's developed a slight exhaust tick on the passenger side so I'll have to address that on my next days off. I'm assuming a loose or broken exhaust stud but haven't had the time to investiage. I'll likely be fixing it myself since the dealer wants the truck for 3-5 days to check a trouble code so I can only imagine how long they'll want it to do any actual work.
The install was fine, the clearance once installed gave me a feeling of dread. I've had an oil filter puncture before due to an oversized filter on a different vehicle so the bias was already planted. The clearance is probably a non issue as the web doesn't return any horror stories, but Murphy's Law dictates I would be the first.I've been using the SRT filter since my first oil change two years ago. No issues what so ever. Would rather have the slight inconvenience of getting the larger filter in and out in exchange for better filtration.
You would have to break an engine mount to cause the filter to hit anything. And at that point, the filter making contact with power steering probably isn't your biggest concern
