Add me to the list. 2021 with air suspension, Bridgestone Dueller tires, outside edge of the front passenger side tire was excessively worn. Got a rotation and alignment at 6700 miles hoping that would fix it. At 13k miles, the tire on that same wheel (which was perfectly fine at 6700 miles) is completely &!*#ed, totally bald on the outside edge. Ram told me alignment is only under warranty for 12k miles, so nothing they could do. But leave it with us for 5 days and we’ll check it out!
 Took it back to where I got the alignment (not the dealership) and they were kind enough to give me a “buy two, get two” on tires. Alignment was only slightly out of spec, so I’m worried that the new tires are going to have the same fate.
One more thing. If you have air suspension, be sure the tech knows to put it in wheel alignment mode before doing the alignment. I thought that he would surely know, but he didn’t. He actually redid the alignment after I showed him. Maybe this wasn’t done at my first alignment and was part of the problem, but who knows.
In any case, I’m rocking a new set of Michelin Defenders and will be watching the wear patterns closely.
