On your stock grill is a backing peice that has all the mounting points, you have to pull off the stock grille front and attach the new one to the backing piece and mount it, that's what all the clip points on the new one line up withTrying to do this install now since it’s almost 80 in NJ. Running into a few problems. I had replaced my old stock grill with this aftermarket one first and then decided to go to the route of the one this post is about and I’m having trouble figuring out how it gets bolted on. My old one has the top posts and everything and this one does not. Any help would be appreciated. Thanks guys.
Is this a Built to Serve edition? I got a 2022 BTS and was thinking to do this TRX grille. It looks awesome man!I got the same grill. I did not like how the letter were spaced out. So I did a little bit or cutting and used washers to secure the screws in the right place. View attachment 116382View attachment 116407
That would look bada$$ and I thought about doing that to but the tape job would be a nightmare!Was also thinking to really go custom and paint the outside surround white and leave the mesh black. No on e has that setup![]()
I want to do mine, but have already spent $1900 this month on the truck. Maybe in a couple months.anyone do this and paint match it yet? might have to be the guinea pig
Rebel grills are a different size.Anyone tried this grill on their Rebel? It says it’s not compatible but not sure what would make it not work out.
AndRebel grills are a different size.
	Was there a specific reason that you decided to swap put the upper rebel grill on and not keep your original paint matched one?![]()
Do you have a link to the plasti dip you used? Ordered one of these that should be delivered 9/3. Like the look of the black letters![]()
