Mountain Whiskey
Mine still works like a charm. It stops when I put it in park and press the button and starts again when I get back in and press the button ready to go. Pretty slick.
			What is the update? I've been getting the "service start/stop" error quite a bit lately. I hardly ever use tow/haul mode - I get the error even if I press the button to disable start/stop. ThanksJust had the update done. My auto start/stop isn't disabled in tow/haul mode. Will update when we hit the road again and are towing more.
Says it was a flash of the HCP (Hybrid Control Processor) module.What is the update? I've been getting the "service start/stop" error quite a bit lately. I hardly ever use tow/haul mode - I get the error even if I press the button to disable start/stop. Thanks
They didn't replace the hood switch the other times! When I went in and looked, they had replaced the hood latch again and I even told them what part!Joining the club, actually been a member of it for many months now. Cylinder 5 threw a misfire code, swapped coil packs with 2 and came back with 5 misfire again. Took it in a month or so ago and they replaced the Fuel Injector. That code hasn't come back yet, but this stupid auto start/stop light is driving me nuts after 2 hood switch replacements. Last one just replaced again yesterday. auugh
Going to trace the wires and see if there is an issue outside the switch.
I would show them this TSB. It was listed as a recall for the HCP on my service invoice.I have a 2021 Laramie 1500 with 17K miles. I am having the same issue with the auto start/stop error light and blinking check engine. Happened in March 22 and they changed a wiring harness and an acuator. Happened again 2 weeks later was undriveable and towed to dealer. They told me I had water in gas and charge me $1600 to fix it. I told them it was ******** and it was the same issue I had in March. I was without the vehicle for 30 days. Got it back and the same thing just happened again so it clearly wasn't water in the gas. I am taking back to the dealer later today so they can throw more parts at it. This is ridiculous they can't resolve the issue when so many people are having the same problem
	Doesn't that TSB only affects '22 models? I'm not sure they'll apply it to his '21. But it's at least worth bringing it up on his next visit.I would show them this TSB. It was listed as a recall for the HCP on my service invoice.
Also would want my money back for the previous "fix." Get @RamCares involved if you need to.
Not sure what they'd do about it, but if he's having the same issue, definitely should be fixed and tracked.Doesn't that TSB only affects '22 models? I'm not sure they'll apply it to his '21. But it's at least worth bringing it up on his next visit.
I’m at dealer now and will share this info with them. Thanks for the input![]()
UPDATE/. Service light went OFF. All is working and even the alert on my phone app is gone.New member, first post!!!
Auto start/stop light came ON. disabled. Light on button OFF.
245 miles. I ll swear my MPG s dropped too as I ve been watching it.
apt made. Wow, not impressed.
