maybe thisCould someone kindly point me to any available YouTube videos or threads on here demonstrating how to remove the 2019+ active air dams without error codes or whatever? TIA!
First off it's ugly as sh*t and secondly it kind of limits my approach angles for the driving that i do.Curious, why do you want to remove?
you do know that the active air dam is out of the way unless you reach 35mpgCould someone kindly point me to any available YouTube videos or threads on here demonstrating how to remove the 2019+ active air dams without error codes or whatever? TIA!
I can't speak for @ramhouston, but I'd be willing to bet he also removed the fixed air dam when he removed the AAD.The active air dam retracts at lower speeds so it should not affect approach angles, the fixed airdam will as it is still pretty low.
The truck looks better without them, in my opinionAgain why would you do this?
Most guys do it for looks. Others, who actually go off-road, want the better approach angle in the front without them. Once you remove the fixed airdam, the active airdam is then visible even when "stowed"Again why would you do this?
I thought it was pretty easy to be honest. Sure, there are quite a few fasteners, but it's not a difficult job. As long as you remove the AAD first.There’s a video or two on how to remove both air dams. I just removed the stationary air damn to add a front hitch for my plow and it was an absolute PITA.
Which one is the AAD? The plastic one attached with fasteners or the automated one? Looking for any help I can get to remove both ari dam piecesI thought it was pretty easy to be honest. Sure, there are quite a few fasteners, but it's not a difficult job. As long as you remove the AAD first.
AAD=Active Air Dam. Remove that one first. Then you will be able to reach the fasteners for the fixed air dam.Which one is the AAD? The plastic one attached with fasteners or the automated one? Looking for any help I can get to remove both ari dam pieces
