Installed some roof racks today. Decided to go this route for kayak transport so I could use the bed simultaneously.
Don't have the big bucks to spring for those racks that work with bed covers.
Catch can and Vararam will make zero difference on electronics.
Trust me...as much as I believe you 100% dealers are just to shady and I just don't trust them. It's a 15 min job to remove that stuff..I'm fine with that.
2016 Dodge Charger scat pack
Nice choice. With the MFT, did you need aftermarket brackets?
Yeah, used the Right On Brackets and stock screws. It was a tight fit both side to side and from to back. The canister barely fit side to side. Then the rails are barely far enough forward for the tailgate to close, while the weather stripping at the front of the bed is almost too far forward. Brackets went on easy though, and probably look better then the stock brackets.
Dude, what happened to your passenger side exhaust tip?? 😟
I cannot keep this Borla adjusted! I have adjusted/fixed it several times and it keeps getting knocked out by the panhard bar/bracket. I need to contact Borla about it, just haven’t made time to do it.
I’ve been very frustrated with the way the Borla fits together. The factory ball socket is a much better design.
I also plan to lower this truck, so the Borla is most likely going to have to come off. I love the sound though. Been extremely pleased with that portion of it.
Easter Bunny stopped by with some Rough Country LED goodies.
Today's install was:
-Rough Country 2" Light Pods w/ DRL
-ZRoadz Light Brackets
-Auxbeam 8 Switch Controller (Will find permanent spot when all lights are done)
Still to go:
-Rough Country 30", Dual Row Light bar w/ DRL
-Shifts and Grins Bracket for 30"
-Rough Country 8" LED bars for reverse
-Motofab 2.5" Front/1.5" Rear Level Kit
-Rough Country Forged Upper Control Arms
View attachment 126654View attachment 126655View attachment 126656View attachment 126657View attachment 126658View attachment 126659View attachment 126660View attachment 126661
How's the light output on the pods? Been thinking about getting those also. I'd rarely use them so I can't justify spending big on Baja's or anything like that.
Like you, I don't use them alot. Got to try them out this morning and they lit the side of the road really well. Considering the super dark corn fields I go through it lit areas my High Beams don't cut it for.
  • pcar
