1.21gigawatts
7-Stringer
Dude, what happened to your passenger side exhaust tip??I de-badged the tailgate
That would be great.If you properly applied the Plastidip, it will last every bit as long as a vinyl wrap, and easier to touch up rock chipsm
Side mirrors is the only thing I didn't doAdded the vinyl side mirror & taillight turn signal tint
I'd look into other places for wrap. I did the same on my 2019 and paid $500 for everything.That would be great.
I spent $50 on plasti-dip and was quoted $1500 to wrap the same parts.
I called up a dozen places and got quotes from $1200-$1800 and was told it wold take 2 full days.I'd look into other places for wrap. I did the same on my 2019 and paid $500 for everything.
Trust me...as much as I believe you 100% dealers are just to shady and I just don't trust them. It's a 15 min job to remove that stuff..I'm fine with that.Catch can and Vararam will make zero difference on electronics.
Nice choice. With the MFT, did you need aftermarket brackets?Installed a RetraxPro XR today.
Then I fully agree with the plasti-dip decision!I called up a dozen places and got quotes from $1200-$1800 and was told it wold take 2 full days.
Yeah, used the Right On Brackets and stock screws. It was a tight fit both side to side and from to back. The canister barely fit side to side. Then the rails are barely far enough forward for the tailgate to close, while the weather stripping at the front of the bed is almost too far forward. Brackets went on easy though, and probably look better then the stock brackets.Nice choice. With the MFT, did you need aftermarket brackets?
I cannot keep this Borla adjusted! I have adjusted/fixed it several times and it keeps getting knocked out by the panhard bar/bracket. I need to contact Borla about it, just haven’t made time to do it.Dude, what happened to your passenger side exhaust tip??
Man that's beautiful!I do, had one since I was 15. On my 8th one now and I'm 65.
View attachment 126676 View attachment 126677
How's the light output on the pods? Been thinking about getting those also. I'd rarely use them so I can't justify spending big on Baja's or anything like that.Easter Bunny stopped by with some Rough Country LED goodies.
Today's install was:
-Rough Country 2" Light Pods w/ DRL
-ZRoadz Light Brackets
-Auxbeam 8 Switch Controller (Will find permanent spot when all lights are done)
Still to go:
-Rough Country 30", Dual Row Light bar w/ DRL
-Shifts and Grins Bracket for 30"
-Rough Country 8" LED bars for reverse
-Motofab 2.5" Front/1.5" Rear Level Kit
-Rough Country Forged Upper Control Arms
View attachment 126654 View attachment 126655 View attachment 126656 View attachment 126657 View attachment 126658 View attachment 126659 View attachment 126660 View attachment 126661
