TNRamGuy
Knoxville, TN
I cut the end off a pneumatic chisel bit, slipped inside a 1/2 pipe cap, took about 45 seconds of 30000 bpm, worked great
Tesla
Ever since we got a lot of snow and ice a few weeks ago, my front sensor will say service required at random times
Joe_Lake
I've had my Tuffy in-consile box sitting around for a year and have yet to install it...
Sent from my SM-G991U using Tapatalk
I knew if I didn't do it right away I would be in the same boat.
Sent from my Pixel 6 using Tapatalk
31RamIt
I ordered it a week before I took delivery of my truck in February '21 aaannnd it's been sitting on my tool bench ever since.
1.21gigawatts
7-Stringer
Boston, MA
hahaha i take it back NOW its the most 2's
22:22 hrs on 2's-day 2/22/22 and logan is on 22R and 22L :ROFLMAO: :ROFLMAO:
1.21gigawatts
7-Stringer
Boston, MA
you're not wrong... but i'm also not wrong... and the mayans, as it turned out... were wrong... you just wait tho, in 200 hundred years, you'll see!!! 🤪
Grape_Ape
Finally got around to installing my Airlift 1000hd airbags. Hopefully picking up a dump trailer next week and hauling a few tons of pea grave. Removed driver side rambox and routed all the airlines to it. Then mounted the fill line beside the power switch for the lights. Not going to use them very often so won't need an on board compressor. I have a handheld 18v compressor that filled them to 50psi without issue to test for leaks. F412960E-E06E-4A65-B5A2-D26D21FF94F8.jpeg
31RamIt
Had my Tuffy Center Console Safe sitting on my tool bench for over a year now. Decided I had nothing better to do tonight after the kids went to bed. So, got that put in. Fits so snug. First time I have ever had a second key on my key ring. Usually just walk around with the RAM Fob.
FLiPMaRC
NJ
