Status
Not open for further replies.
BowDown
Frisco TX
I'd be willing to bet the 3.92s might actually have a higher top end without a speed limiter as they could overcome the drag easier than 3.21s
Nope. look at the 1st page post 17, top speed would likely occur in 4th or 5th given the hp and aero. All the 3:21 truck would need to do is be in 4th when the 3:92 is in 5th which actually gives the 3:21 truck better gearing. Would be the same for 5th or 6th as well, advantage....3:21
1594143543070-png.61167
The Hellcat challenger guys ran into this with the 2:62 vs the 3:09 gear during airport races. 3:09 cars hit a dead spot around 160 mph and slowed dramatically while the 2:71 cars didn't shift and were able to pull the gear because they were still in peak power.
Here's one example but there's many more https://www.hellcat.org/threads/redeye-vs-hellcat-3-09-vs-2-62-1-mile-race.230459/#post-4110577
Since nobody really knows what the aero limited top speed is on these truck, you are just making a WAG with what gear the trans would be in
BowDown
Frisco TX
Wouldn't matter.
You said gear wise the 3:92 truck would be at an advantage. Unless both trucks could max out in 8th gear, the 3:21 truck would always have the advantage as the gearing one gear down from the 3:92 truck has the 3:21 truck with superior gearing as the chart clearly displays. After 1st gear, the 3:92 truck has zero advantage gear wise because of the trans.
Wouldn't matter.
Since you don't k ow what the aero limited top speed is, once again, you are just assuming the 3.21 truck would be a gear lower. Depending on the speed and shift points, there is a distinct possibility the 3.92 could be hitting top speed at the top of 6th where the 3.21 would have to shift into 6th because it had too much RPM in 5th due to higher gear ratio
theblet
Maybe with 37’s so you’re final drive will be better for top speed. But the rotational mass of the load range f tires would prob prevent any gains associated.
Mountain Whiskey
Wouldn't matter.
Or the little blonde chick driving the truck with 3:21 gears would hit a slight head wind and BOOM. Dead in her tracks.
ferraiolo1
North Central PA
Unless you have a bolt on intake that gives you 30+ hp lol
Only if you think they will be in different transmission gears. I love how the 3.21 guys latch on to the whole, my truck has better gearing if I'm one gear below a 3.92 truck. Well, no ****.
BowDown
Frisco TX
You can manually put/keep the 3:21 truck in a gear lower. The +/- button thingies on the wheel. Keep trying :LOL:
BowDown
Frisco TX
So, if you're in 8th and I hold 7th, guess where we are? Me with a slightly lower gear than you. Outside 1st, that's the case in every gear
Yep but you'd be out of motor, math.
But wait , there's more! I can do that for every gear till you're out of gear or motor
These trucks will be aero limited before they hit 8th gear. So any advantage you think you have by being in a lower gear doesn't matter as much. There will be a time when both trucks will be in the same gear at the same speed as the 3.92 trucks reaches top of gear and 3.21 trucks has to shift into next higher gear, losing any advantage it may have had. You can't change the rules of physics
Status
