I might have just never noticed it before. There's so many little things like that easily overlooked.Mine had it before, but I wasn't on a very old release.
Would be same as 12"Where can I get updates for my 8.4 with nav?
ThanksWould be same as 12"
Read the posts aboveSo I just did the latest radio update. Where in Alpha OBD do I go to change the setting to enable the performance and offroad pages? This is my first time using Alpha OBD so hold my hand step-by-step please. Just can't figure out which menus & sub-menus to enter..
Dude, I read dozens of pages and everyone just gives the final settings to adjust, but not how to get to them. BUT - I played around for a bit and found it (I turned Performance Pages and Off Road Pages to Yes.) However, they still have not shown up. I do NOT have ORP, and saw a setting for something like "Off Road Capable" I wonder if I have to change that to Yes. Not sure what else may need to be done for the performance pages.Read the posts above
You have to be on the latest update PR 39..
You need to enable them with AlfaOBD
Below gives you the off road pages and performance pages.
VehConfig 1-Performance Pages Present = YES
VehConfig 2-Off-road Capable =YES
VehConfig 5-Off-Road Pages Present =YES
You have to get a TazerDT for that function. And it's a "live" function for the TazerDT, meaning it has to be plugged in for it to workI found the Off-road pages useless for my 2wd and will be turning them back off. Anything relevant to my truck or useful is duplicated in the performance pages so that’s all I really need.
Still trying to get the global window feature to work. I would say it’s not possible in our trucks but there’s a YouTube video of a guy with a Rebel that demonstrates the option.
I have enabled both Global Window Down and Up, and found where you can set it to do both front and rear windows, or just front. Now I’m wondering if I have to enable something in the remote itself????
Thank you for your help. That's what I kept coming across (forgot Off Road Capable + Yes) but didn't know where or how to find "VehConfig 1" etc.! lolPost # 1,119. Made it easy and quoted it for you below…
Can someone state the order of the software updates?.. With P39 being the newest.. I’m at LR 34.2 and do not know which update to do next? Thanks again
Post #1241
I tried to install PR 39.7 today but I got a message saying the update wasn't compatible.Thanks
The equivalent update for the 8.4 is different. I believe another member offered to send the 8.4 files if requested. I'll see if I can find that post.I tried to install PR 39.7 today but I got a message saying the update wasn't compatible.
I appreciate that!The equivalent update for the 8.4 is different. I believe another member offered to send the 8.4 files if requested. I'll see if I can find that post.
Here you go. It appears that @Edmontonram has the file you need.
AlfaOBD
thanks to all of you, for the help. so figured out that having the NR28 in order to update it to the PR39 i needed to update to the LR34 first. That is correct, i was already on LR34 when i began and also read in previous post that you would beed to start there in order to get the PR39 update...5thgenrams.com
