Anyone ACTUALLY running 5w-30 or even 10w-30? Thoughts? Experience? Any REAL TRUTH to throwing a code running higher weight oil (no conjecture please)
Status
Not open for further replies.
silver billet
The engine sounds like nothing out of the ordinary and you call that a problem and that the factory weight oil is incorrect. You sound delusional. Then you think that based on your experience hauling your groceries home every Friday, that me, already towing the same 7k# trailer over 125k miles with Hemi engines don’t know what I’m doing by following the Factory Service specs.
Like I wrote earlier, your advice is poor with nothing to back it up but your opinion of what you think you hear. You should try spending more time behind the wheel listening to the sound system instead of under the hood listening to the engine imho.
You sound upset :)
I tow a trailer all the time in the spring/summer/fall months. My hemi sounded normal. When you drove it it sounded just like every other hemi that I test drove, and also my brother's who happens to own a hemi, and a few friends who also own hemis. I'm very familiar with the "normal" hemi sound. When you replace that factory oil with RL, it quiets down. This is a fact, and it's not just something I noticed. Many users have reported this, and some have even video'd the evidence which is clearly noticeable.
I have hit 250 degrees while towing up a small hill in the summer. There are also way too many reports of temps getting past that on much large mountain climbs: 255, 260. If you're still using 0w-20 at those temps, well then you are nuts. No other way to put it. The hemis do not have a large enough oil cooler.
0w-20 is a fuel efficiency oil. 5w-30 is the oil you need when working it. And RL just happens to be the oil which kills the hemi tick and quiets the general valve train noise. Apparently facts are offensive these days, who knew.
IvoryHemi
I don’t understand why Ram would publish the 30-weight requirement for 14k+ lbs GCW if oil weight didn’t matter
NOTE: For 2500/3500 trucks with a 5.7L engine operating under a gross combined weight rating of 14,000 lbs (6 350 kg) or greater, SAE 5W-30 engine oil is recommended for all operating temperatures.
Cbty2050
They haven't used a 5.7L in the 2500/3500 truck in how many years?
silver billet
2017 3500 5.7L is the same as a 2022 1500 5.7L?
The 2500 5.7 does not have MDS.
In the user manual for the 1500 5.7 they said (paraphrasing) 30 weight oil may prevent MDS from working. Nobody running RL 5w-30 or 0w-30 has ever reported problems with MDS not working, it's a non issue in reality.
ekaz
My dealership put 10-30 in my truck without advising me. I read the invoice and had them re do the oil change. Two oil changes later they did the same thing!!!!! Now my name in their computer is MR 10w 20!!! Use what the owners manual and oil cap say. And eat your peas and carrots. And if you Google the Twitter to much you will go blind in the one eye!
Didn't you just start another entire thread where you are listed at MR 5w20 cause they put in 5w30?
MontFla
Still getting used to the site? I thought that was a reply to something
Cbty2050
P1521 is a code that can set. It's odd I know.
Idahoktm
North Idaho
There is no such language in the manual. As a matter of fact, I can't find any reference to MDS in the owner's manual.
silver billet
The code is definitely real, and if you go out of bounds too far with the viscosity it will appear. But I haven't read any reports of RL 0/5w-30 setting the code off in either a 4th gen or a 5th gen.
silver billet
Note how they recommend 5w-30 in the 2500:
Status
