Idahoktm
North Idaho
Anyone compare the OEM step to the AMP Research step. AMP step looks wider and also seems to protrude more than the OEM.
*Edit: they're also pretty much the same price ~$290
Even if it was $100 cheaper, I wouldn't buy it. It's just too damn ugly. 🤣
bigdodge
Happy Ram Owner
just arrive my locking gas cap
if any of you are worried about these DT trucks not having a locking gas cap this one is for you. they have them for gas and diesel
gas
GeorgiaBoy
Georgia
gas
Yep! Got mine yesterday. Not really concerned about thief or vandalism around where I live so probably wont have it on most of the time. But when traveling out of town overnight I'll feel more comfortable having it.
Jeffjad
Southwest PA
Tinshield
Nice, how exactly did you run your power supply to the USB port? Is it completely hidden?
They include a long cable. Ran it up under the mirror housing, under the headliner, down under the door molding and behind the glove box.
There is an adapter available that give you a plug in behind the mirror so you don't have to route any wires down pillar or across dash.
Tinshield
Yeah I saw that but I don’t see a port on the back of the mirror in my truck. Maybe there one inside the mirror housing, I don’t know as I didn’t actually open it up. Wire routing literally took less than 10 min anyway.
U
User_34235
Guest
i want to do that.
is it as easy as the video shows?
I did not remove a single panel, just reached up and grabbed the three prongs and pushed. You will lose some skin on a piece of metal that is up there or at least I did....lol.
Dont forget to remove the silver ring that is on the old switch and move it over to the new one.
Overall it took me less than 5 minutes to do once I started.
TexasDrone
Will this work on a 2019 3500 too.
2019 RAM 3500 Longhorn Megacab
2021 RAM 3500 Blackout Megacab
2019 OpenRange 3X427BHS
2020 Jayco NorthPoint 382FL
2021 Luxe Elite 42FL
2022 Grand Design Solitude 380FL-R
2021 Jeep Grand Cherokee L-Summit
I don't see why not, but I can't guarantee
You plug the adapter inline with the connector for review mirror and it gives you a USB port. Yes you have to take off the plastic housing around the mirror. It's more about not having to route a wire than the time it takes. Also don't use up a USB port below radio.
TexasDrone
Never mind. It does list Ram. I ordered one.
