Tinshield
- Nov 23, 2021
What kind of wheels? Look great.slapped some new wheels on her today! Toyo AT3 305/45r22
Do you mean the rims? Those are the factory 22" Laramie Night Edition RimsWhat kind of wheels? Look great.
Yeah, I thought so! Thanks. They do look great.Do you mean the rims? Those are the factory 22" Laramie Night Edition Rims
FWIW, tires go on the wheels. Wheels bolt to the truck. People use "rims" and "wheels" interchangeably. But wheels is the correct term.Do you mean the rims? Those are the factory 22" Laramie Night Edition Rims
What were you getting when you had ANC turned off?OK, after 70 miles, I had to turn ANC back on and reverse the polarity of the 6x9 back to the factory setting.
Everything back in phase and the ANC turned back on is hopefully going to be a closed book.
Could you please link the lights you used? Looks awesome!Finished up my reverse/flood light install. For anyone interested they’re just the typical white Amazon rock lights used as puddle lights and the reverse lights. 4 on each side of the truck on the frame rails and 4 flush mounted in the rear bumper. These aren’t some super bright show quality lights, but they’re inexpensive and almost give off an OEM+ appearance. If you need back up lights to illuminate more than 10ft then get some more substantial lights though haha View attachment 116912
Wheel is considered the whole thing. A wheel is made up from two parts, the rim and tire.FWIW, tires go on the wheels. Wheels bolt to the truck. People use "rims" and "wheels" interchangeably. But wheels is the correct term.
These are the ones I used. SUNPIE Pure White LED Rock Lights https://www.amazon.com/dp/B019ODAK2...abc_PYB1KEBWWXSTM6H0215R?_encoding=UTF8&psc=1Could you please link the lights you used? Looks awesome!
Is that why when you order a tire/wheel combo from Tire rack, it's called a tire/wheel combo, and not just a wheel?Wheel is considered the whole thing. A wheel is made up from two parts, the rim and tire.
TyThese are the ones I used. SUNPIE Pure White LED Rock Lights https://www.amazon.com/dp/B019ODAK2...abc_PYB1KEBWWXSTM6H0215R?_encoding=UTF8&psc=1
Keep in mind, these come with no wiring harness so you have to make your own! There are some other options that come with quick disconnect harnesses and they’re way easier. For the rear I daisy chained them together using butt connectors with heat shrink and solder and then ran my LONG wires into the engine bay where I have my wireless control box so that I control the lights with the homelink buttons on the visor. For the puddle lights I just tapped into the driver’s footwell light so that they turn on whenever I unlock the truck or open the doors.
We’ll I’ve been using those terms wrong then thank youFWIW, tires go on the wheels. Wheels bolt to the truck. People use "rims" and "wheels" interchangeably. But wheels is the correct term.
how well does that thing work? would love to have the wireless capability for my apple car play...Plugged in the wireless CarPlay my wife got my for Xmas. Open to other mount options. Appears to work fine, a bit underwhelming fit and finish for $100.
do you have a link to the lights or did you do a write up on them?Finished up my reverse/flood light install. For anyone interested they’re just the typical white Amazon rock lights used as puddle lights and the reverse lights. 4 on each side of the truck on the frame rails and 4 flush mounted in the rear bumper. These aren’t some super bright show quality lights, but they’re inexpensive and almost give off an OEM+ appearance. If you need back up lights to illuminate more than 10ft then get some more substantial lights though haha View attachment 116912
Hmm good to know. I disabled mine when I put my muffler. I just reinstalled everything so going to give it a shot see if I can tell a difference.Hard to explain. It didn't seem to be audible, but I was getting a headache from driving. It was like some pressure impulse was being generated in the cab from the expansion joints in the road. Maybe it was the speakers pushing inward instead of outward.
