 - Jun 8, 2021
- Solutions
 - 1
Generally it’s available on that site immediately. But if you check the link too often, you won’t see the window sticker (due to caching on your device). I’ve found that, even if you clear your cache regularly, the link can’t be checked more than once in 24 hours. But without getting into the gobbledygook that triple_B uses to help bypass the caching, you can alternately try that same link on one of the other servers (Jeep, Dodge, Chrysler) in lieu of Ramtrucks.tripleB does Window Sticker updates every night at around 9:30pm CST and does build sheets every morning around 9:30am CST.
If you want to manually lookup your build sheet on a weekday you can use this link https://fcacommunity.force.com/RAM/s/equipment-listing
If you want to manually lookup your Window sticker you can use this link (You will have to input your VIN after the =): https://www.ramtrucks.com/hostd/windowsticker/getWindowStickerPdf.do?vin=
Do note, it does take a while for the manual lookup site to get your window sticker. tripleB is able to get it much sooner than the manual lookup website. - I don't know how long it takes to populate there, I just know the day tripleB was able to provide me the WS I wasn't able to view it on that website.
