- Jul 25, 2020
I installed mine on closest hole from the get go and never looked back. I wanted the firmest setting. Not compromising my handling.Got the Hellwig on. One of the brackets didn't line up so I need to reach out to them or get the dremel out. Was able to use the Hellwig poly bushings with the factory brackets, so I might just leave it. I put them on the middle hole.
Initial impressions are good. Just drove it a few miles.
Anyone run them on the most aggressive setting?
Someone else has same issue with the Hellwig sway bar brackets. They contacted Hellwig and they sent them a replacement. It's like someone grabbed the wrong bracket out of parts bin
