Does mounting them backwards appear to scuff the front of the wheel? I'm considering ordering an extra stock wheel and tire to use as a spare. Didnt know it mounted that way.Got the used tire mounted to the spare Built to Serve wheel to use as a full size spare since I went with 34" tires. 275/65/20. It just fits with the stock heatsheilds and hitch receiver in place. You aren't getting anything bigger under the truck without removing one or both of those things. And this tire is about 1/2 tread.
This looks amazing. Make sure to post a pic once they're mounted!View attachment 112826
These got here a week early. 4Play 4PS60, 20x9, 0 offset. My tires are waiting for me at Discount Tire, Pirelli Scorpion AT Plus 275 60 r20's. Sometime next week they will be installed.
That is a good looking truck! Perfect stance. Some guys get carried away and drop the truck so low, that it's not really drivable. Nicely done.Cleaned her up before the winter comes.. gotta get the 22's back on but not today!
View attachment 112920 View attachment 112921
Thank you sir!That is a good looking truck! Perfect stance. Some guys get carried away and drop the truck so low, that it's not really drivable. Nicely done.
Man, that's a slick *** truckCleaned her up before the winter comes.. gotta get the 22's back on but not today!
Thank you sir!Man, that's a slick *** truck
I'm not worried. Maybe if I was modified more, but basically stock, so should be able to handle it. And it's not a constant thing. Few nights a year. Make 6-10 passes a nightI’ve always been nervous about that given how small the front driveshaft is, can the 4wd system really take hard launches like that consistently?
That's the way the stock spare is mounted, and really the only way you can mount it. The cross bar on the cable that holds it up won't work the other way. And unless you are running stretched tires the sidewall of tire will keep the wheel front touching anythingDoes mounting them backwards appear to scuff the front of the wheel? I'm considering ordering an extra stock wheel and tire to use as a spare. Didnt know it mounted that way.
I hope you have more than just the single ground cable to the body.View attachment 112938
Upgraded the big 3 for the electrical system to 1/0 wire
That's interesting, I've never seen anyone put a fuse on a big three.View attachment 112938
DO NOT SELL THAT TRUCK. It is a one-of-a-kind Bizarro truck. Everything on it is backwards.Just got inside from switching the silver letters on the grill to black. Could’ve painted them or vinyl but I chose to use Amazon and just ordered black letters.
The A was a pain to get off but the R and M was super easy.
Used a razor blade to get inside because they are clipped in tight but once you get them off the new ones snap right on like legos and who doesn’t like legos.
Here is the link to them, I got them for $35 a week ago. The price went up for some reason:
Nice!!!!Cleaned her up before the winter comes.. gotta get the 22's back on but not today!
Thanks you...Factory air suspension with lowering links..probably around an 1.25". This pic is in entry/exit mode.Nice!!!!
Is that leveling springs in the rear and a 2 inch in the front?
