Post your pics of 37s and give some feedback!
Chris VB
Ontario Canada
75.81 mph @ 1500 rpm
Jr22
EastBay
@Carlos.33193 What fender flares are you running? My 20 limited is getting lifted on the 15th this month going down to 20's on 35X12.5 Nitto gridge grapplers. Great looking truck man
Jr22
EastBay
thanks for the info guys. I agree with Chris they look just right colored match.
Jr22
EastBay
You might clear them going down the road Straight ahead until you turn the wheel lol. 6in bds here with 35s on a 20x10 and I have a little rub on the back of the fender at full crank in reverse.
clean looking set up! going the same route 20X10.5 on 35 nitto grapplers
Ruben705
I found a setup on custom offsets that showed 37's with 3.5" ReadyLift. 20x9 +1 using a 11.5" tire. I've tried finding the actual person to discuss this but can't find them. Anyone in here ever tried to squeeze a 37 under a 3.5" lift? I don't want a 12.5 or 13.5 tire.
Idahoktm
North Idaho
Nice! Thanks man. Is your speedometer calibrated? Mines not calibrated
That makes sense because I'm at ~1950 rpm at 75 mph with 33's with a calibrated speedometer. Your speedometer is off by about 10 mph at 70-80 mph.
Chris VB
Ontario Canada
Yes it’s calibrated. I wish I could lend you the module… it’s one time use and was $300..
maybe I’ll use it on my new TRX one day….
Idahoktm
North Idaho
You can spend $100 for AlfaOBD and use it as many times as you want.
Chris VB
Ontario Canada
One time use as in I’ll never use it again lmao, I’ll always have 37’s ;)
And that’s what 4wp charged me (CAD) so it sounds like I got hosed lol w/e
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
Ahh gotcha! I haven’t calibrated just because I don’t really mind my speedo being off because I just go with the flow of traffic usually lol. But it would be nice to see my correct mpg! I have to hand calculate everything.
Idahoktm
North Idaho
Hand calculations won't work either because your odometer is off too.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
Yep I know the odometer is off. The odometer, speed, and mpg is off. But I know my tires are 14% larger than stock (I’ve calculated and tested it) so I know my odometer, speedometer, and mpg are off 14%. So at 66mph on the truck I’m actually traveling at 75mph. Every 100 miles I actually travel 114 miles. And if the truck says 11.6mpg avg then it’s actually 13.3mpg (according to the truck itself - but surprisingly my hand calculated numbers are usually really close too). I find my true mpg by taking how many miles the truck says I drive (usually about 280 miles per tank), multiply that by 1.14 = 319 miles. Divide 319 miles by how many gallons it takes to fill up. Usually 24 gallons to drive 319 miles, so I average 13.3mpg.
Idahoktm
North Idaho
Yep, you've got it figured out. I was just discussing this with another member and while he was aware of the speedometer error, the odometer error slipped his mind.
