bigdodge
Happy Ram Owner
- Aug 25, 2021
- Location
- southwest. where majority rules
weird for sure.Thanks - that confirms that the window sticker is 0708, but the door is 0720.
Weird...?
Weird...?
They’re referring to the MDH numbers on the door jamb sticker vs the SL numbers at the bottom of the window sticker. In the below pic, that truck rolled off the line October 3rd in the 15th hour. It’s window sticker shows October 4th as the SL number.Nope. Mine only has the day and month. I know it was 2018 because I bought it in January 2019![]()
That makes sense, so you think you have the actual air dam under there or are you just referring too th lower valance.Parts shortage thing for a month or two or so around the time my truck was built back in May. So if you see window stickers from around those times (I guess I would just say spring of 21), expect to see the active air dam delete. And it just has a fixed air dam instead, probably the standard one I would assume? Here's some pictures I have on my computer that show it:
Ugh, helps if I'm looking at the MDH and not just the Built date.weird for sure.
The active air dam lives tucked up behind the fixed air dam (lower valance). If the active air dam isn't installed it's just empty space behind the fixed air dam. The fixed air dam is the same regardless of whether you have the active air dam or not.
