PorBoy
All great questions and the reason why I said it would need to be “ proven “ to be effective “ through research I would even began to shell out that cash.
							did they mention avalibaliy ? and price ?
I’m only going off of these photos of which I truly appreciate you taking, but that Ram Air doesn’t look like much. Of course I am not an engineer so I cant say it won’t flow well.![]()
That's my big question. I would love to make some modifications to my truck, but I'm worried about the voiding the warranty that I dropped loot on.Some folks will not put any upgraded parts on their vehicle unless it's made by the manufacturer as they are paranoid it will void their warranty without knowing about the Magnuson–Moss Warranty Act. $900 is a good amount of loot to drop on that upgrade but I'd rather wait and see what the true aftermarket releases after SEMA.
It looked "flimsy" the way the plastic was molded was far from perfect. In one of the pictures if you zoom in you can see the generic acordian hose going to the throttle body, not exactly optimal for performance, but I'm not an engineer either....
Definitely not as nice in person as the original RAM photos show.
The accordian style hose is for flexibility and motor movement. If they didn’t, it would snap/crack if a solid mount was used.
That’s why most intakes have this design or thick rubber connectors that allow for movement. The motor does not stay still during operation.
The magnuson most act only states that a warranty cannot be voided because of the addition of aftermarket parts, it still affords the manufacture or dealer then right to deny individual warranty claims as long as they provide written proof that the aftermarket parts caused or contributed to the failure of the part that failed. Really what's this means is although the act offers some consumer protection it does not mean you can slap whatever part you desire on your truck and not assume some risk of a failure that will not be covered. Exhaust and cold air intakes and have an engine failure probably bot an issue, go into the ecm and have it "tuned" and have an engine failure you may be screwed, a lot of this also has to do with your dealer service department. Once upon a time you just pulled the AM parts before taking it in, ECMs these days are much more sophisticated and can now create log files that show everytime a change has been made regardless of whether everything has been put back to stock, basically a history of programming changes still exists, I do not know if the new ram does this or not. The reason I mention this is most people that are adding exhaust or CAIs need programming changes to really see any substantial benefit from the additinal parts gone are the days of super restrictive factory intakes and exhaust systems to where just the net flow through the system results in additional HP. Typically factory programs are set with some safety factor and often what is being done when its tuned is leaning out the a/f ratio and advancing the timing curve, this does create more power but increases the chance of engine damage making it a lot easier for a warranty claim to be denied. Just something for everyone to keep in mind when modifying their rig. Some dealers are very performance friendly and oriented and others are not, so just know who you're dealing with when choosing your mods.Some folks will not put any upgraded parts on their vehicle unless it's made by the manufacturer as they are paranoid it will void their warranty without knowing about the Magnuson–Moss Warranty Act. $900 is a good amount of loot to drop on that upgrade but I'd rather wait and see what the true aftermarket releases after SEMA.
