harman kardon is nothing than a bag of trash
what is your bass setting?
  • Total voters
    84
dandar
I wonder if it's crossed wires to the amp or different sources for speakers and subs at the factory but there is a huge variance in HK sound on these trucks. Mine is extremely bass heavy. I have my bass set at -5 and at loud volumes it still overpowers the highs.
Buz
Disconnect your sub and you'll think you got a new stereo. I did it and it's night and day. The hour of work to do it pays in dividends.
Isaiahjw
My cousin has a 19 Laramie/Longhorn with HK and I have the Alpine in my 20 Limited. I think the Alpine sounds a lot better.. Not enough “oomf” behind the HK despite its crystal clear sound but maybe there are limitations to the base in some? Even he has said my music sounds so much better
mikeru82
The Palouse
I've had both the Alpine and the HK systems. And for what I listen to the HK is a lot better sounding than the Alpine. No comparison. It does really matter what your music source is though.
Sascwatch
AM, FM and SiriusXM aren’t nearly high enough quality to get the full potential out of the Alpnie or HK systems. A high quality source like Apple Music, Spotify, etc. Are the way to go.
I think my HK system sounds amazing and could actually use much much more base on certain tracks, all of my passengers think it sounds amazing aswell. This is with the bass set at +5 and sound deadening installed in all four doors and on the rear of the cab.
Sound quality is going to vary between stations aswell, my local FM rock station sounds like crap and is all bass so maybe that’s where people are having issues?
Idahoktm
North Idaho
I've never had SiriusXM until I bought my Ram. The sound quality is so much better than my local FM stations, I quit listening to them.
The bass is a big part of why I like the HK system so much. I can feel the music.
Sascwatch
If you have a smart phone hook it up to your truck with Spotify or Apple Music and it’ll sound even better. SiriusXM is a step up from even HD radio but it’s nothing compared to the bitrate of some music streaming services.
Using a USB cable rather than Bluetooth will sound the best.
Idahoktm
North Idaho
I just tried Spotify, Samsung Music, and SiriusXM from my phone via USB. Spotify and Samsung Music sound the same and both are a little better in the high and mid frequency range but not a big improvement over SiriusXM.
cw_mi
Coming from a person that used to have an aftermarket system installed in every vehicle, my HK system in my '19 has to be the best sounding OEM system I've ever heard. Now, that said, I've always drove trucks, so I can't compare how a high end sedan would be compared to this. Now , I do see quite a bit of difference in audio depending on the source. Radio stations suck, some satellite stations suck, I generally listen to .mp3's from a flash drive and they do sound much better.
RJS
Very true. In fact, the smartphone can also make a big difference. My go-to streaming source is Amazon Music HD and my HK system sounded great with an earlier LG thinq7 phone. it was replaced with a Samsung S21 5g and I went back to using the LG as the sound was better. Just replaced the S21 with a Samsung Flip3 and it's the best sounding wired setup I've had using AA in my 19 Laramie with the HK system.
RQLTIGER
Where can I get instructions on how to disconnect the Sub? I have a 2021 Limited and the Bass is disappointing IMO. I listen to a wide variety of music, and for treble leaning songs the HK is amazing, but Bass sounds boomy. Would replace whatever I need to to get a balanced sounding system. Don’t want to take my entire under back seat storage up though. I had a 2014 Longhorn with the Alpine system and I thought it sounded better than the HK honestly. Any suggestions?
Sascwatch
How to unplug the sub? Directions?
You will have to remove the rear passenger seat and move the rear panel to access the sub and it’s wiring. You may even want to remove both rear seats to make it easier.
