Under certain conditions my air suspension doesn't return to normal. If I notice it I just hit the up. In entry it is just a rougher ride.I've been able to drive on entry/exit mode a few times now. Is this something I should be concerned about? Here's a video.
Thank in advance!
Yea mine only does it when I lower with fob too. But I can lift when I get it with the button. Does yours lift? It should not be "stuck" In EE. The ride is super bumpy like thatMy truck sticks in EE since day 1 (over 2 years). I had it back to the dealer several times, they attempted to fix it and after they could not they said it's normal ? The odd thing is that it only sticks when I lover it with the fob but not on the dash. I have 10 months left on my warranty am wondering if it's worth fighting for. My main concern is what does it do to the tires driving it in that mode ?
Yes, it is out. Front end geometry is fixed. I'm guessing RAM has the front end alignment dialed in somewhere between normal and aero mode height since aero gets a lot of highway miles.Yes it will lift manually and does automatically 80 percent of the time. I just wonder is the caster/camber out when it's in EE? I drove about 400 miles once in EE before I noticed it.
where did you see that in manual ?If you lower it with the FOB it will stay in Entry Exit until you manually tell it to lift up. Its a feature not a bug.
There's a dozen+ threads on it being so herewhere did you see that in manual ?
Air Suspension not returning to Normal mode after Easy entry setting.
Anyone else having trouble with the suspension not returning to the Normal position after selecting the Easy entry mode on it's own? Mine will only go up to the Aero mode but won't go into Normal mode unless I manual select it again.5thgenrams.com
lower then drive off. if you let it sit until the ecm goes to sleep it resets.Not true. I lower mine with the fob every time I wash it, when I drive away, it raises itself, the indicator on the evic actually says "raising"
that's just the oldest thead theres lots more.Seems like those were predominately all early builds, 19's and even some of those functioned normally.
				I agree, definitely not a "feature" even when I lower with key fob most of the time it will auto rise once speed is increased. I've only managed to do it a handful of times. And everytime I was messing with thr key fob right before. As I stated earlier. I've also been able to raise the truck from the Key fob. I don't think that was an intended feature either. I think my system is very glitchy.No one is disputing that some people have trucks with this issue. Nor are we arguing that there aren't any other threads about it. What we are disputing is the fact that you called this a feature. It is not normal behavior, and is certainly not a feature. It is most definitely a bug. Are you calling it a feature because someone who made the last thread you linked jokingly called it a feature?
