TRX baby brother
robe2388
Looks great. Quick question, I just installed the TRX wheels on my Rebel with 2" spacers and It rubs when wheel fully turned. Did you have to mod the liners? Thanks!
gizmo5
I’m also leveled. And yes, I removed the little plastic “mud flaps” and trimmed liners. I also massaged with a heat gun and pulled the liners to the rear with zip ties.
I barely rub on one side at full turn and compressed, that can be fixed with caster adjustment but it’s not enough for me to go get it redone.
Whoa_Ram
Azle TX
Not sure about this brand. The name of this small metal tube is “EVIL OFF-ROAD DESTROYER,” might be overstating things
To each their own, but I don't like that personally.
robe2388
Perfect thank you sir I’ll try this!
Shifts And Grins Fab
5thGenRams Vendor
5thGenRams Vendor
Gilbert Arizona
We will definitely build front bumpers at some point. I am not sure when we will get to them but I want one on my truck so hopefully a prototype or two will be out before too long. lol
robe2388
SWFLRebel
Fort Myers
Quick update, took the “mud flaps” off and cut liners up until tires wouldn’t reach them any more and no rub now on regular air settings. Looks fire I say.
Aired up ^
Aired down
Looks sick, I have the same setup (silver and black). Question, what are the stock tire sizes on the TRX? I know they're 35's, also what's the offset and width of the wheel if you happen to know that? Thanks
gizmo5
TRX OEM tire is GY Wrangler Territory AT 325/65/18
Steelwheelz
CT
Little bit of plastiDip, some TRX shoes, and a couple aluminum pucks stuffed in the right spots…
And I ended up with this, a baby Rex lol
(massaged some plastic and metal tabs for the liners to not rub)
What size spacers did you use in the front and back?
preston42
How well has the Plasti-Dip lasted on the skid plate since you put it on 6 or so months ago per your post? I've been thinking about doing this in the short term but just curious how well it's lasted over your duration of having it.
mikeru82
The Palouse
Can't speak for him, but from my experience with the 2017 Rebel skid plate, plastidip can be pretty durable. It held up pretty well to 2 winters in Eastern Washington. But the first time I took it into a wheat stubble field I knew it was time to replace it with bed liner before the 3rd winter LOL.
ALT_F13
Seattle, WA
Main question - where you guys are getting TRX wheels from? Are you buying OEM wheels and tires separately, or you were lucky to find used ones on Ebay/Craigslist?
gizmo5
Found a TRX guy who went aftermarket and 37s
I jumped on the $1500 deal
ALT_F13
Seattle, WA
Is using 2" wheel spacers really required to fit these wheels on Rebel, or it is more for the looks? I'm curious if a small spacer like 3/8" will clear the upper control arm, and such small spacer will not kill bearings long term.
gizmo5
I had them before the wheel swap. No idea if they are needed. I just dig the perfect look.
as for wheel bearings…. If they die, they die. I’ll buy more. But I’m willing to bet they last a solid 50,000+ more miles
ALT_F13
Seattle, WA
Thanks man! I've ended up with installing 1.5" spacers and modifying the front wheel wells. No rubbing at all, there is plenty of space there.
