IvoryHemi
- Jan 3, 2021
so, is the Rebel "effectively" a 3.79, or is the regular 1500 a 4.05?
It’s the former.
Depends on how you want to look at it really. You could put on larger tires that "effectively" give a 3.92 geared Ram a 3.21 ratio, but you aren't getting same "benefit" for fuel mileage as a factory 3.21. so the whole "effective" ratio BS, isn't even worth talking about.It’s the former.
Yes, a larger tire will give better fuel mileage on the highway because it drops the RPM’s. (Compared to an equivalent smaller tire).
HSKR R/T is right. None of this is worth talking about. Understand that it is not just rpm but the effort it takes to move the larger heavier tires that anemic 3:21 gears struggle with. Just get the 3:92 gears so you will be satisfied with your truck and not have to hide your shame of owning a truck with 3:21 gears with denial.Depends on how you want to look at it really. You could put on larger tires that "effectively" give a 3.92 geared Ram a 3.21 ratio, but you aren't getting same "benefit" for fuel mileage as a factory 3.21. so the whole "effective" ratio BS, isn't even worth talking about.
Bravo. I feel like a learned something today. Thanks for sharingI hope this post will help to end the debate with facts and not opinions, and become THE post people refer to those who are having a hard time deciding.
You already know that 3.92 is better for towing, and 3.21 gets better fuel economy, so I will talk about what you might not know
Bottom line up front:
In layman's terms, to conceptualize the difference, imagine
1) 5 out the of 8 gears have the same final drive ratio between 3.21 and 3.92.
2) 3.21 has "an extra" overdrive gear.
3) 3.21 has 2 unique lower gears for towing.
4) 3.92 has 3 unique lower gears for towing.
5) Speed range that 3.21 is better at towing: 31-38 MPH, 48-57 MPH.
6) Speed range that 3.92 is better at towing: 0-30 MPH, 39-47MPH, 58-70 MPH.
Explanation
1) 5 out the of 8 gears have the same final drive ratio between 3.21 and 3.92:
Here's the gear ratio for the 8 speed transmission:
1) 4.71:1 2) 3.14:1 3) 2.10:1 4) 1.67:1 5) 1.29:1 6) 1.00:1 7) 0.84:1 8) 0.67:1 Reverse) 3.30:1
Final drive ratios with 3.21
1st. 15.12, 2nd. 10.10, 3rd. 6.74, 4th. 5.36, 5th. 4.14, 6th. 3.21, 7th. 2.70, 8th. 2.15, R 10.6
Final drive ratios with 3.92
1st. 18.46, 2nd. 12.31, 3rd. 8.23, 4th. 6.55, 5th. 5.06, 6th. 3.92, 7th. 3.29, 8th. 2.62, R 12.94
From the list below, we can see that gears 3-7 in 3.21 matches gears 4-8 in 3.92:
-- NO MATCH -- = 18.46 - 1st - 3.92
3.21 - 1st - 15.12 = -- NO MATCH --
-- NO MATCH -- = 12.31 - 2nd - 3.92
3.21 - 2nd - 10.1 = -- NO MATCH --
-- NO MATCH -- = 8.23 - 3rd - 3.92
3.21 - 3rd - 6.74 = 6.55 - 4th - 3.92
3.21 - 4th - 5.36 = 5.06 - 5th - 3.92
3.21 - 5th - 4.14 = 3.92 - 6th - 3.92
3.21 - 6th - 3.21 = 3.29 - 7th - 3.92
3.21 - 7th - 2.70 = 2.62 - 8th - 3.92
3.21 - 8th - 2.15 = -- NO MATCH --
2) 3.21 has "an extra" overdrive gear:
The 8th gear in 3.92 is the 7th gear in 3.21, thus effectively mean the 8th gear in the 3.21 is an extra gear to the 3.92.
Meaning, when you go test drive the 3.21 you will have to downshift to 7th to get the same acceleration at 3.92's 8th on freeways. That is why some people complain about how "sloppy" the 3.21 is, because the 3.21 has an extra overdrive gear for fuel economy. If you shift 3.21 in 7th gear, you will get the same acceleration as the 3.92 in 8th on the freeway. No, 3.21 isn't sloppy, you're just in a gear that 3.92 does not have.
3) 3.21 has 2 unique lower gears for towing:
As we know from 1), 5 gears have the same final drive ratio.
You "gain" an overdrive gear, but you "lose" one towing gear.
Here's the final drive ratio for the 2 towing gears.
4) 3.92 has 3 unique lower gears for towing:
Same logic as the last
Final drive for 3 towing gears.
1st. 18.46, 2nd. 12.31, 3rd. 8.23.
5) Speed range where 3.21 is better at towing: 31-38 MPH, 48-57 MPH,
AND
6) Speed range where 3.92 is better at towing: 0-30 MPH, 39-47MPH, 58-70 MPH:
Calculated towing shift point to be 6000 rpm, if I'm off the logic is the same but the speed will vary.
For towing,
From the speed 0-30 MPH, 3.92 has higher final drive ratio over 3.21 (18.46 vs 15.12) until it has to shift to 2nd gear at 30MPH.
From the speed 31-38 MPH, 3.21 has higher final drive ratio over 3.92 (15.12 vs 12.31) until it has to shift to 2nd gear at 38MPH.
From the speed 39-47 MPH, 3.92 has higher final drive ratio over 3.21 (12.31 vs 10.10) until it has to shift to 3rd gear at 47 MPH.
From the speed 48-57 MPH, 3.21 has higher final drive ratio over 3.92 (10.10 vs 8.23) until it has to shift to 3rd gear at 57 MPH.
From the speed 58-70 MPH, 3.92 has higher final drive ratio over 3.21 (8.23 vs 6.74) until it has to shift to 4th gear at 70 MPH.
The key takeaway here is that towing heavier trailers uphill with 3.21 might never reach the desired speed within the 58-70 MPH range (typical highway towing speed) because 3.21 jumps from 10.10 to 6.74 without the 8.23 final drive ratio found in 3.92 that really help maintaining highway towing speed at max load.
Do you value the "extra" overdrive gear for fuel economy? or do you value the extra towing capability that you tell yourself you might one day need? That's up to you.
The differential gearing isn't giving the entire picture. Gotta love new transmissions with their lower initial gearing, multiple gear positions, and high final drive ratios.HSKR R/T is right. None of this is worth talking about. Understand that it is not just rpm but the effort it takes to move the larger heavier tires that anemic 3:21 gears struggle with. Just get the 3:92 gears so you will be satisfied with your truck and not have to hide your shame of owning a truck with 3:21 gears with denial.
I know. I just see a lot of guys get real worked up on this thread and it is fun to troll it a bit.The differential gearing isn't giving the entire picture. Gotta love new transmissions with their lower initial gearing, multiple gear positions, and high final drive ratios.
What would be a better gear ratio if you plan on lifting your truck and putting 35’s on? The 3.21,3.92 or the 3.55?I hope this post will help to end the debate with facts and not opinions, and become THE post people refer to those who are having a hard time deciding.
Explanation
AND
For towing,
What’s your opinion on etorque or no etorque?Go with the 3.92. The 3.55 is not available with the hemi.
We had the same question before we ordered. We ended up test driving both back to back to see if there was much difference. In our test drive, it was immediately obvious that etorque had much smoother gear changes.What’s your opinion on etorque or no etorque?
I drove 3 Ram trucks when I was shopping. They all had 3.92 gears but the second one had eTorque. That was the only Ram that I didn't like. I don't know how to describe it but it felt draggy on deceleration...like it had additional engine braking. During acceleration, it felt the same. That sealed the deal for me...no eTorque.What’s your opinion on etorque or no etorque?
