silver billet
- Apr 18, 2019
Very nice write up. I have the 2020 1500 Classic, 392 ( I mean to say 5.7 Hemi — confused as my first Hemi was the 392 hemi of my 1956 St Regis), 3.21, 2wd.
Towing my 5000 lb trailer seems best in 6th gear which I need to select manually, as the tow mode typically runs under or at 2000 rpm at 57 mph. Where can I find a torque curve for this setup? What would you suggest as the optimum cruising rpm As the cruise control selects 7th ?
Appreciate your insight.
I typically pull at 2300 RPMs or so, little more little less, but in 6th gear. My truck picks that gear naturally, but I do lock out 7th just because sometimes it might want to upshift for a few seconds.
So I put it in TH mode, and then use gear limiter to lock it down to 6th.
