jimothy
That is a neat idea! .. I'd do the same but inside my RAM BOX .. do you have a list of part numbers or links where you obtained them (aka Amazon)?
If you’re going to install in the Rambox, you may just want to use an AC-to-12 volt adapter since you’ve got a 115V outlet in there already. Nonetheless, these are some of the parts I used:
Cigarette Lighter Socket Panel,... https://www.amazon.com/dp/B091GFZ3TL?ref=ppx_pop_mob_ap_share
LYCAEA 60 Amp Circuit Breaker for... https://www.amazon.com/dp/B07TSFF2GQ?ref=ppx_pop_mob_ap_share
Blue Sea Systems m-LVD Low... https://www.amazon.com/dp/B00GZOP53M?ref=ppx_pop_mob_ap_share
6 Way Blade Fuse Box Fuse Block... https://www.amazon.com/dp/B08XJ9SCSB?ref=ppx_pop_mob_ap_share
25ft - 1/4 inch PET Expandable... https://www.amazon.com/dp/B071WF5K2X?ref=ppx_pop_mob_ap_share
I got the braided sleeving in two sizes: 1/4 and 3/8, and two colors: red and black.
Plus a bunch of wire (6, 12, and 18 gauge), battery lugs, split wire loom, heat shrink, wire cutters (I didn’t have anything adequate for 6 gauge), and crimp connectors. Oh and this nifty but expensive crimper, which can do anything from 22 gauge to 4 gauge:
Wirefy Crimping Tool Set 11 PCS -... https://www.amazon.com/dp/B092MRZ5JK?ref=ppx_pop_mob_ap_share
This ended up being a pricey project, because I had to buy tools and supplies I didn’t have on hand.
