InfinitySurf
It is 4x4, I added that to my sig
Is your truck 4x4? It isn't listed in your signature...thanks for filling it out though.
Towing number gets a little crazy to figure.Interesting, I realized the other night that could not be right, when I saw others posting their payload and wondered why mine was at the very top end for that model and when looking at 4x4 with short bed, it did not go that high on towing. Before buying the truck, I asked dealer to send me confirmation of exactly what the payload and towing ratings were for this truck...the 1840 and 11,340 was what they sent me in the document, I looked at it again to confirm. Obviously they were wrong as I just looked at the door sticker and it says 1516 payload. How do I confirm the towing number for this specific truck?
Thanks for heads up as I am a bit OCD about stuff like this. Even tho I dont ever push the max, I want to know what it is.
I got one with 3.92 and Tow Package, now I am trying to find a solution to revert back to the power folding mirrors that are standard on Level 2 equipment group and deleted by adding the Tow Package.
Basically GVWR is 7100 GCWR is 17000. So you have to weigh stuff or use the SAE J2807.
Read this thread for more explanation
https://5thgenrams.com/community/th...et-my-needs-or-am-i-waiting-for-the-2500.437/
As you see, 150 lbs each for 2 passengers...I weigh 290 myself.
So 7100 minus your payload of 1516 gives you an estimated weight of 5584.
So 5584 from 17000 is 11416. So with nothing else in your truck the max tow is 11416...but there has to be a driver and other things.
So you can continue the math with your real numbers or use J2807 and get close, which would be 370 lbs and tongue weight...so 11416 minus 370 is 11046 so a 10 percent tongue would be 1105, but that will take from your trailer. So it looks like about 10000 lb trailer give and take your actual payload and actual tongue weight.
Hope that didn't confuse you and atleast gives you a real close idea.
The increased capacity is the new Dana Super 60 axle. Of course, it is in a quad cab 2 wheel drive bighorn.not what I was expecting after reading all the glowing ads about increased capacity.
I have a 2022 ram bighorn crew 4x4 black widow that has the 3.92 gear ratiois this from your payload sticker, or one of the online configurators like build and price or the Ram site tow configurator.
I ask because A. That is a very high payload, and B. 1840 is what the configurator gives usually
Will be curious to know
