jefferyrw
Does that date correspond to the build date on the sticker on the inside of the driver's side door frame on your truck? I ask because there is conflicting information as to whether the number on the window sticker is the build date or the date that the window sticker was produced.At the bottom of the window sticker (directly above the barcode) there is a line that has the vin, then the von and then some (very small) numbers. For example mine was built 5/14 and appears on my window sticker as 0514.
