Official Built to Serve Thread
Do you own a Built to Serve edition w/ the 0249AC springs
  • Total voters
    29
  • Poll closed .
Rjshoaff1
Akron, Ohio
Orders in our area are a long wait. When driving by our local Ram and Chevy dealerships you might think they were going out of business.
Yeah the dealerships parking lots around me are like… post office parking lots on a Sunday! Empty
joiafour
Does anybody know what the details are around the BTS lift? Is it a small leveling kit? Is it the same lift that comes with the offroad package? I haven't been able to find any information on this.
SaltyMac
The Built to Serve is the same as the offroad group as far as lift height goes. Same springs and struts/shocks at 1" over stock height.
Sent from my SM-N970U using Tapatalk
Wookie0323
This little lightbar makes a HUUGE difference in backup visibility! Only downfall is the way the tailgate lowers, I couldn't keep my old Coast Guard plate cover. It barely rests on it now when it is down. Guess I'll have to get a Decal instead.....🤪
sweetwillyj
I have had that light bar on since last year and I really recommend it. Big difference in visibility.
HEMITKN
York, PA
Big difference!
Wookie0323
Did you tap into your reverse tail light or trailer harness? I did the trailer harness because it was less work and I read a few people say the other option sometimes threw a code for some reason
sweetwillyj
Passenger side tail-light and no issues code wise, that I know of yet. I had to lose my St Louis Blues plate frame too. Not sure if there’s enough space to slide a frog’s hair between the light and lowered tailgate but it hasn’t broken so far.
Rjshoaff1
Akron, Ohio
Some one posted these vinyls decals a couple weeks ago. Mine came in today. I was nervous about the greys match. I guess I’ll wait and see once they fully adhere. Nice BTS touch I thought tho
bud007
Earthquake country
I have a few question concerning the spare tire for the BTS model as i was reading another thread concerning the spare tire , or lack of.
i crawled up under the truck ( bad back and all ) and i did see the spare ... looks full size , but on a different rim. So my questions are , first does anyone know what size the spare actually is ? is it a 20' rim ? also is it possible to order one of the Built to Serve rims so that i can mount a spare tire on it , mainly so i have a correct spare and to use when rotating the tires , and if so will it fit in the spare tire spot up under the bed ?
sorry for the questions , but with the back ,( and wish it wasnt like this ) i try to limit my time up under the truck. (y)
GKIII
DFW, Texas
The spare is a 275/65 R18 while the OEM tires are 275/55 R20. So the wheel + tire combo are essentially identical in overall size, meaning an OEM BTS rim + tire should physically fit in there.
However, the center bore of the BTS rim does look smaller than the spare rim's, so it may not be possible for the OEM bracket on the spare tire mount to fit through the BTS rim bore. Not sure though as I haven't measured them. If that were the case, I'm sure there are aftermarket solutions out there.
Grape_Ape
I want to say people have gotten a spare BTS wheel and mounted it up there fine. Could be wrong though. Just what I seem to recall.
I picked up two OEM wheels from a user in our BTS Facebook group last week. One to replace a curb rashed wheel I had and another for an eventual spare. I suppose I could let the spare down and see if it would fit the spare bracket.
bud007
Earthquake country
Grape_Ape
yeah , i would be interested if you do . i have seen these wheels come up from time to time but usually for all four. I think these wheels are somewhat special ( i could be wrong ) but i wonder if you can order one from a dealer ? i might have to look into that.
if it works out for you , i might have to keep my eyes open and check FB occasionally . (y)
Grape_Ape
You can order them from the dealers but will pay the regular retail price or an OEM wheel. Which would probably be $300-$500 per wheel.
SubMech
Just picked up a BTS edition without knowing what it was, did some research and found this thread, disappointed that I ended up with a coastie model but I guess I can get over it. Not much on this thread of the white versions so here goes.
