Maxx102
Twin Cities - Minnesota
Did you drill through both the rubber and plastic? Any chance you could get a pic of it mounted into the dash?
So no drilling is required and you remove the rubber pad. I just put mine in the glove compartment.
The mount included two long screws which you will use to mount it using the factory hole locations.
The bottom of the mount also has that super sticky automotive grade adhesive from 3m. Just remove the red backing paper and line up the mounting holes on the mount to the factory holes on the dash and tighten it down. Don’t over tighten it however otherwise you will strip the hole out.
it does come with two short screws which will require you to drill. Using these is optional and completely unnecessary if you only plan on mounting a couple of phones or theIr GoPro mount. Tablet / iPad i can’t comment as I don’t have one and don’t plan on using one at that location.
I hope this helps.
NorthernArea51
NY
I hope this helps.
Awesome. Thank you!
MikeyHo808
Hawaii
I installed the black 5" Mopar tips and had the same experience with the offset on the driver side and passenger being different. I actually want the passenger tip to be in the same position as the driver side. :unsure:
I took them off and reset them, and the offset is not as bad now, but now they sit more under the bumper than the stock tips, like I could use another 1/8 to 3/16 of pipe…wt….f…grrrrrr🤦🏻‍♂️🤬
Klicht87
Mystic, CT
You could always have a exhaust shop weld on some extensions.
Moosefire66
First time ever seeing this stuff. Is there anyway you can explain how you install this? I’m assuming you have to lift up the floor boards ?
I've never used it but it's a sound deadening and helps to limit heat in the cab too. It's sticky so yes pull the carpet up ant stick it to the metal of the floor, wall, ceiling, wherever you want or need it at
1awesomelaw
Lol, you're gonna be mad about this comment, but I can't help myself...
You know, underneath that tonneau cover, there's a big space called a "bed" - that would be a perfect place to put all those bikes!
you cant fit all those bikes under that cover unless you jam them all together, plus where's the coolers of beer going to go.
Idaho970
Boise, ID
My plan is to remove the rear seats and pull back the carpeting to get access to both the rear wall and floor panels up to the front seats. If you search sound deadening (or Dynamat since this is the brand name of what I'm using) you will see a ton of info as to the benefits of the product. My main goal is to get quieter cab - I know that sounds silly since I strapped on a Boral S-Type - for when I have to drive around my buyers/coworkers. Secondary goal, and why I got the closed cell foam - the noico 150m - is to help with a little bit of heat transference. It will help keep the AC in during the summer and keep the cold out in the winter. I'll put up a thread when I install it so shoot me a PM or follow me to see my next posts.
GadgetMason
South-central MA
Following!
Seabass4592
Not today but this month! Step bars, Gator Tonneau cover and floor liners, weathertec underseat storage tray, tint all the way around, seat covers and bed and tailgate liners! Got it the way I want it now!
El_Draque
raining and couldnt get good pictures. Today I painted and installed bumper plugs where they drilled for the front license plate holder, I also installed black lug nuts and McGard locking lugs, and I also installed Huskyliner mud flaps
