Gpenny
- May 14, 2021
I've been browsing the forum for inspiration for awhile now but first time posting so hi all & thanks in advance for any feedback on this. Picked up my 2021 Ram Rebel (4x4 w/ Air-Suspension) in December & it's still completely stock but looking to make some minor mods soon & hopefully starting with a 2" level.
I know this thread might belong in the 'Suspension" sub forum but because the Rebel sits an inch higher than the rest of the trims I think my question might be unique to the Rebel. I've been looking around for 2" kits but I can't seem to find anything that will work with air-suspension and/or the Rebel. All of the options (linked below) I found with the exception of the Revel Links either note not for use on air-suspension trucks and/or the Rebel trim.
The only options I could find that look like they could work are these from Revel Performance:
1) Revel Air Suspension Links - The description notes that these are compatible with the Rebel but with the caveat below. So if I'm understanding correctly, you can only raise the front ~3/4" and lower the rear a bit to get a somewhat level max lift of ~1.75".
"Since the Rebel Rams are already lifted from the factory any adjustment higher than ~3/4" in the up direction will result in a harsh ride. It is possible to use the lowering links to drop the rear of your Rebel to achieve an almost level ride, just specify in the notes when ordering the kit that you want the Front lifting and Rear Lowering links."
2) Revel Air Suspension Links w/ Daystar Leveling Kit - Revel's website notes that this is the better option for the Rebel but the below disclaimer is a little concerning. Looking at the leveling kit directly on Daystar's website here and it does say "excludes models with air suspension". The Revel description notes compatibility for model years 2019-2022, however, the description on the Daystar site only notes through 2019 (maybe that doesn't matter?).
Does anyone have any experience with either of the Revel Options? Or any other 2" leveling options for a Rebel with Air Suspension that won't cause loss off Off-road 1 & 2? Based on my research so far it seems I may need to just hold off a bit until a manufacturer comes up with a legit solution. I really want to level the truck but not sure it's worth the risk with these somewhat round about options unless others are having a good experience with them.
Standard 2" Level Options that exclude air-suspension and/or Rebels
"Disclaimer: Although Daystar specifically excludes air ride Rams for this product, when used in combination with the Revel adjustable sensor links they have been shown to install and function properly. Customer to install and use at own risk. All Sales Final, no returns or refunds."
2
2019-2021 Ram 1500 (including Rebel) 2WD/4WD 2 inch Leveling Kit w/ new Tubular Upper Control ArmsFor use on New body style Ram 1500 4WD. Not for use on classic body style Ram 1500. Also fits Rebel Edition Front strut extension leveling kit Not for use on air-suspension equipped trucks CNC...
www.readylift.com
2 Inch Leveling Kit | Air Ride | Ram 1500 4WD (2019-2024)
2 Inch Leveling Kit | Air Ride | Ram 1500 4WD (2019-2022)
www.roughcountry.com
2 Inch Leveling Kit | Ram 1500 2WD/4WD (2019-2024)
2 Inch Leveling Kit | Ram 1500 2WD/4WD (2019-2022)
