Installed Bushwacker Flares, modified rear most spat to work with the flares and cut fender liner bracket in anticipation of my 2" front wheel spacers (2.5 for back - BORA)
Going to look a little funny for probably a month or so until they come. Tires set in too far for my liking but I wanted to get flares install they take up too much space in garage.
Keep on or remove? Debating this.
Changed the oil for the first time on my truck. Just over 5k miles. Also swapped the cabin air filter. Seems like they added another obstacle in the way of the oil filter when I compare my 2019 and 2021. Some wires and plastic clips. Pulled those out of the way and used the ziplock bag method, which actually worked like a charm this time.18825F5A-7EA2-4966-8D64-F0855B4AA753.jpeg
View attachment 91010View attachment 91011
View attachment 91012View attachment 91013
Keep it on, matches piece on lower part of the bumper.
Put on the Carven Polished 5” tips this morning (Moes has a great deal on them). They don’t look much bigger off the truck compared to the stock but I think they look really good installed.
My new Ridge Grapplers finally came in this week. The 295/65R20s fit with no rub on stock rims with the Motofab 3/2.
Thanks! Yeah I am back and fourth on that. I'm going to leave them on for now and see if they grow on me. When you zoom in on the picture you just see the plastic not wrap under the truck and it's sort of in mid air if you get what I'm saying.
But that was the exact reason I put them on after cutting so they would match the piece coming from the bumper.
The issue is where I cut, it just looks "unfinished" because it just stops. Even though I put on rubber edging.
Mines only two days old to me and I'm loving it! Put Weathertech window deflectors on front driver and passenger sides. Every vehicle I've owned in the past 25 - 30 years have had these. Da bomb! More to come of course. Oh, and sorry, didn't take a picture.
I got some worse than crappy AVS's as Weathertech wasn't out yet last year. I'll ripping that mess out as soon as get these.
So much better than the puny 4 inch. Great job!
My puny 4'' tips look ok to me. I like the black chrome :cool:
Those Carven tips do look pretty sick, though.
My MBRP muffler has arrived! Hopefully, I will get to it in the next week or so. Been busy busy.
Found the perfect spray paint for OEM running boards.
New Aluminum Pedal Inserts installed...Sold by Motrobe on Amazon for $20. Nice fit and looks better than OEM rubber pads. Tight fit and about 10 minute install. Link below.
Dangit dude just when I thought I was done buying stuff for the truck 😒
You should adjust them a bit, it makes them fill out the opening better in my opinion :)
