SurfRebel20
 - Oct 3, 2020
the fox 2-3 was my original plan until i saw these. I personally think they look better and have always wanted kings. i only want an extra half inch than what you got maybe I could put a half inch spacer on top of the strut hat. also I would think we would need the 600lb spring seeing as these are intended for non rebel rams and the rebel is quite a bit heavier. maybe it wouldn't have settled if going with 600lb spring? I wouldn't mind paying the 300$ for custom length either if gaining that half inch was possible that way. i also really like how the king rears are inverted so you can actually see them as the fox is standard only making the rod visible in the rear.You could go with the BDS kit (4 inch.) or Fox DSC (2-3 inch.)
