King Shocks/Coil Overs came in!
Hello Rebel owners,
I have a question regarding front brake lines before I start installing the fox 2.5's. With 2.5" of total lift including the 1"ORP will I need to extend the brake lines or will I be ok? Any suggestions are greatly appreciated.
Thanks
Sent from my SM-G996U using Tapatalk
Hello Rebel owners,
Thanks
You lose the 1" ORP with the fox coilovers. So, you're fine. If you have the extended travel Fox's they can be set from 2"-3" (they come set to 2"). 2.5" is the diameter of the shock body.
I do have the extended travel Fox's, and I'm adding 1/4" more threads above collar for 2.5", so no extended front brake lines needed. Got it.
Thank you
So, what is everyone's center of hub to fender numbers? I currently have the RL UCA's and a 3" front, 2" rear block and am ready to upgrade. Im looking at the king setup, just wanna see what everyone's looks like
