I’ll post more when I get it back from the shop on Saturday.
I’ll take a couple of other angles tomorrow but I’m really really pleased with how this came out. The lines on the roof are on point and I love the look from inside the cabin. Still get a ton of light in there.
Been looking at these but wasn’t sure in the details of plug and play like they say. Did you have to get a harness for them to work? And does it use a fuse tap to power the running lights? Thanks
So it is a direct plug in, no harness needed. The fit is dead on.
The harness that comes with it to add the daytime running lights, doesn't fit, BUT, I didn't want that feature anyways, although, if you do want to add it, you just have to order a $5 adapter for it on Amazon, no biggie.
Let me know if you have any other questions. More than happy to answer.
Sent from my SM-N970U using Tapatalk
Replaced my older prior-gen Valentine V1 with a Uniden R7, and also replaced my broken Car2Play dongle with a AirlinKit brand, so a fun day all around for the Silver Bullet. :cool:
Do you know possibly know what the adapter needed is so I could order all together? And I’m guessing the light output is definitely better than the stock halogens ha.
Yup, light output is definitely better.
This is the wire, so you just have to cut the wire they send you and the end where in plugs into your fuse box and replace it with this one, should work fine. Hope it helps.
Today i installed my Tazer DT and adjusted for tire size & tire pressures , also ordered my winch Zeon platinum 10 , this winch will just be easier to run having a remote clutch, using a SwarfWorks mount .
Removed, cleaned, re-greased, and reinstalled my Hellwig sway bar. It was getting a little “creaky” when lowering the truck. Went with the middle setting this time, and I’m liking it so far!
Dang I wonder if that is what I hear sometimes when I lower mine. Now I have to go check
Installed my Pulsar. Drove down to the gas station and filled it with 93, then drove around for half an hour. Pretty pleased with the upgrade :D
I ordered these utility rails. I want to get the riv nuts installed before I have it coated with Line X.
my truck came factory with these. super handy for adjustable tie downs. i have some plans in the works to build a folding awning mount so i can get an awning on the truck.
quick ipad sketch on what i’m thinking. i have some notes somewhere on some fasteners from amazon that will work with the rail, so i can build some other stuff once i get the awning together.
my truck came factory with these. super handy for adjustable tie downs. i have some plans in the works to build a folding awning mount so i can get an awning on the truck. quick ipad sketch on what i’m thinking. i have some notes somewhere on some fasteners from amazon that will work with the rail, so i can build some other stuff once i get the awning together.
Your truck came with the Bed Utility Group which is why you have the rails.
