This week I was able to get the A/C TSB applied to my truck and I would like to share feedback on my experience with everyone:
A friend sent me the attached pdf file for the TSB so I immediately call up my local Ram dealership and said that I wanted this specific TSB # applied to my truck. I explained to them that my A/C performance has been terrible since I purchased the truck new. The service guy looked up my VIN# and verified that my truck's build date fell within the affected models of trucks. He said everything is okay and I would need to schedule a drop off so they could begin an engineering work order and order the parts. A week later the parts came in and I was scheduled for the install.
The truck was kept for 2 full days and when I picked it up I IMMEDIATELY noticed a difference in the A/C performance. Mind you, I live in Phoenix, Arizona where we are currently experiencing 80 degrees days this week! (Sorry everyone else
) The vents actually blow COLD air (like most every other modern vehicle) and the fan speed seems to have increased when set to Max A/C. More importantly, I can now comfortable ride around in the truck with the auto temp set to 72---with the system maintaining a reasonably low fan speed and a slight push of COLD air coming from the vents. Prior to the TSB, because I live in Phoenix, nearly 100% of the time I would have my system set to full auto cold or Max A/C. At this setting the fan speed was always pushing air at super high speed trying to cool the cabin temperature...but as we know, our A/C system was so weak that it would never reach a cold temperature, and the crazy fan speed was just part of my 5th gen Ram ownership experience. Not anymore, after the TSB fix!
THE BAD:
(Mind you, in the desert it gets pretty chilly before 10 am....before it shoots up to 80 degrees.) The cold works amazing but now the heat doesn't blow from the forward facing vents in auto mode. The only way to get heat blowing from the forward facing vents is in manual mode. (Conversely, air does blow from forward facing vents if set to LO temperature in auto mode, which is weird). I took it back to the dealership and they were aware of the problem, since the one other customer who had the TSB fix had the same complaint afterwards. I guess the new software is set to prioritize cold performance, so now I will have to wait until the new software is released to control the heat in auto mode. Not to worry, I feel like I will survive the remainder of the winter since I live in Arizona. A cup of coffee plus my heated seats and steering wheel should keep me alive...but I understand how this could be a HUGE deal for those living in winter states! In my opinion, I find it somewhat peculiar that FCA would release unfinished software with a TSB fix.
If anyone else has the TSB applied to their truck please confirm that your system is performing the same as mine?
