Roaminglost
- Jan 8, 2020
do you have photos of before and after?As perfectly described above, I netted about 1.5” from the Fox setup you listed.
Link to before and after: https://5thgenrams.com/community/th...-2-5-dsc-883-06-166-install.23136/post-396060do you have photos of before and after?
I'm not sure what RebelWraith did, but the Clayton springs will give you 1.5 Inches of lift over the stock Rebel springs. I have a decent amount of weight in my bed which all the time (diamondback HD plus tray and gear) which lowers that by about .5 inches. I wanted a small rear lift because being perfectly level guaranteed that I was front heavy any time I put something in the bed.How did you get 1’ extra lift in the back? Am I correct to say that Clayton springs will give you +/- 2 inch lift vs Rebel spring height?
Replaced the factory rear rubber upper spring perch with the Daystar polyurethane upper spring perch that adds approximately 1".How did you get 1’ extra lift in the back? Am I correct to say that Clayton springs will give you +/- 2 inch lift vs Rebel spring height?
Are you able to get a measurement for me? center of the wheel to the bottom of the fender on the front.The 2-3" extended travel 2.5 DSC coilovers from Fox if set to 3" of lift (they come set at 2") will only net you 2" over a stock Rebel height.
The model number is : FOX-883-06-166. Fox lists this model to only be used with aftermarket UCAs.
Here is a picture of my Rebel with 35s and Fox 2.5 DSC front and back. 1" lift in the back as well.
Right at 2". An 1/8" under maybe and running true 35" tires.@RebelWraith did you measure the before and after height change? For whatever reason it doesn’t look like it’s +2” over Rebel height. Are you running a true 35” tire or a metric equivalent like a 295 70 18??
Copy that. Your truck looks awesome. Curious as to your center hub to wheel well / fender measurement.Right at 2". An 1/8" under maybe and running true 35" tires.
There are still threads to go further down on the shock body. I was given data from FOX that to go further down the body and provide more lift I would need a different spring which they do not have yet. I'm not too worried about going any higher though as I don't want to limit the life of the CV axles anymore than I already am.So I'm curious, why did you net only 1.5" from these extended length coilovers?
And as a question to both you and @RebelWraith : Are both of you guys maxed out on threads, like cant even go a fraction of a turn more?
As an unrelated general side note about these coils: At like $1000 per coilover, I would have expected an additional locking ring vs tightening screws on the perch ring to lock. Especially given these are meant for off-road trucks.
I could crank them more if I wanted, but I don't feel it is necessary or helpful. I'm running stock tires so the lift is really aesthetic right now. I also have plenty of clearance for 34's when I feel like I need an upgrade. With all the offroading I'm doing, I only run full size spares so I'm limited on tire size to what will fit under the truck. I bought spring compressors and adjusted them on the truck to get a little bit more lift. However, I'm quite happy with the stance and rake that I have now. When I first started, I thought I cared about the truck being level, but what I really hated was how low the front end sat. Once the truck was level (first with Bilstein 5100s and then the Fox coilovers) I realized that the rear was also too low and I HATED that the truck would be nose high with stuff in the bed. That's when I picked up the Clayton springs and Core Swaybar links. I'm extremely pleased with the stance and performance. I started with the 5100s and hated the ride. They were very stiff. My goal with Fox was to get enough functional lift without sacrificing the performance at all.There are still threads to go further down on the shock body. I was given data from FOX that to go further down the body and provide more lift I would need a different spring which they do not have yet. I'm not too worried about going an higher though as I don't want to limit the life of the CV axles anymore than I already am.
One thing to note is once you get to the point of compressing the spring enough to adjust the locking collar for 3" of lift the spring is touching the discs on a commercial grade spring compressor. So, what am getting at is if you do set the FOX coilovers at 3" of lift you have just enough spring gap that when the coilover is at full compression the spring almost becomes solid. Anymore adjustment and you'll hear clatter from the spring clapping it's coils while offroading.
FOX really cheaped out with just the one locking collar. If I had to guess too many people adjusted them incorrectly on their vehicle causing damage to the threads on the shock body (There is a proper way if you have both collars). The way it is set up by FOX now you need to remove the coilovers to adjust them or compress the springs on the truck and adjust the collar. I've seen some sketchy videos of people backing out the lock screw 1 turn and beating the collar around to compress the spring. The collar is rather soft metal and so is the shock body. I'd rather not destroy something this expensive.
