Etorque lag?
RambleOn
I just test drove a 2021 limited with a 5.7 etorque (3.92) and a laramie 5.7 no etorque (3.21) and the limited seemed to lag a lot off the line compared to the Laramie. The Laramie was responsive and the limited felt sluggish, does that sound right? I am very confused by this experience.
Just right off the bat. There is probably a good weight difference between the 2.
That’s a factor, but the way it reacted I want to rule it out. Bad window stickers? Is that a safer assumption? I need to drive a few more is the bottom line. Trouble is no one 50 miles from me has much.
Etorque should be faster off the line. The electric motor gives u 1/2 a wheel turn advantage off the line. Also the 3.92 should smoke 3.21 off the line. You would need to compare apples to apples. Also u can hot the A button by the shifter so the motor doesn't shut off at a stop.
Probably just needs a flash. I wouldn’t be concerned about that.
Aside from weight (and that is dependent on options), the Limited has the advantages of both eTorque and a 3.92 rear end.
I specifically ordered my Longhorn with both options in order to overcome the sluggishness I felt when test-driving non-eTorque trucks with 3.21 gearing. And in my review of the first eTorque truck to show up on a dealer lot, I demonstrated that it was possible to break the tires loose while starting the engine, so even start/stop isn’t a disadvantage for eTorque.
It may just come down to a difference in pedal position, seat position, or current transmission profiles (there are 45 shift programs that can be learned based on driving style). It also could be a difference in “feel”—but not necessarily speed—due to the Limited’s air suspension, presuming the Laramie has coils.
Good luck to you!
I’ve never driven a 3.92, but stands to reason that it should be quicker off the line than a 3.21, so I’d try test driving a few other similar vehicles since it may be just that one truck that’s different.
Like @SpeedyV said, it could be a number of things.
Cheers,
Thanks for your response, very helpful. But what do you mean by this? Does the transmission 'adapt' to the way you drive the truck?
I would like to know what you mean by flash as well. Sorry if it's a stupid question, I have never heard that term used before.
All RAM's have severe throttle lag. The eT should perform better as stated by @Big D. That's why everyone needs to buy a Pedal Commander (or equivalent) to wake this truck up! I had no idea what I was missing until I was convinced to buy one. Best $300 I spent on this truck :D
I echo the Pedal Commander. It has changed the driving experience. I have never spend so little on something so easy to install that makes such a drastic difference. Dial it in and drove on!
Thanks for the advice. Do you have a link handy?
With my previous 2019 Ram Laramie Sport 3.92 e torque and my wife’s current 19 Ram BH Sport 3.21, we installed the Vitesse Throttle Controller. I’ve had them on my previous 5 vehicles. Even the tuned ones; better on-the-fly adjustability.
I’m used to 500+rwhp cars and it was a must. Ram has throttle lag but no where near GM. Fords have gotten better.
Same application at PC but half the cost. An option for those wanting to save a little money.
