Mopar Introduces The Ram Rebel OTG Concept For SEMA:
NewLove
Any one know if they put wheel spacers on this truck to fit the 35X12.50’s?
NewLove
I would say no. The 2 inch lift and the properly back spaced wheels should allow for no spacer needed
Those wheels are same specs as factory Rebel wheels. 18X8 +19 offset. Is there any way we can find out?
devildodge
Moderator
Central Pennsylvania
The mopar Bighorn has the same setup. I do not know how you would know...but I am guessing that there is no spacer. 2 inches should be plenty to fit a 35 inch tire. But again...i do not know. I would assume if they used a spacer...it would be listed in the mopar parts list. I would place my bets on no.
NewLove
The lift definitely will clear the 35’ tire. I’m concerned about the inside of tire rubbing the Upper Control Arm. ?
NewLove
Do you know where I can find the parts list for this truck?
