arod412
NJ
Didn't work on the truck...just played in some sand/mud. I could spend all weekend working on either ram or charger, but sometimes you got to play
Owner of a 2020 Ram Laramie (leveled with 2" rc struts and 1" rear spacer on 33.5" toyo open country) , 16 Dodge Charger scat pack and my wife 21 Jeep Wrangler Unlimited Sahara (2.5" rc lift with 35" duratracs)
securityguy
North Florida
That's all the mud you could find? That can happen just going through my neighborhood ;)
MayhemMOORE
Got ceramic tint all the way around today. 70% over the factory rear and 15% on the front windows. Also installed my black Gorilla lug nuts which look so much better on the black wheels.
Jako
Borough of Parks
No, the ecodiesels come with the heater so all you have to do is purchase and plug in the cord. From there it’s just deciding whether or not you want to install an aftermarket outlet like the noco or not. Cord was $42 from the dealer. Took 15 minutes start to finish.
Thanks, I didn't look at your tag line. I have the Hemi.
securityguy
North Florida
No they are not. I figured why not, since I have it.
I was heavy into CB's when I was a kid. Put them in my Mom and Dad's cars as well as my Grandfather who was totally into electronics, and I had a base station with Single Side Band and a huge roof directional antenna on a rotor and used to talk all night long. Loved those days!
skylarfaucett
washington
Trucks at the dealership for mopar level,
Just ordered these kmc 20x9 0 offset with Nitto Ridge grapplers 33x12.5!!
Stoked!
arod412
NJ
Ah....your one of those guys that like to "one up" someone. Well, im perfectly fine with this type of mud and sand on a new $54k truck.
If it was a 10-15 year old $5k jeep, or truck, then of course you want to beat the crap out of it.
I like getting just a little dirty, then cleaning up later for a car/truck show.
securityguy
North Florida
Not trying to one-up anyone...just found it funny as most pics you see of guys getting their trucks "dirty" they are VERY dirty ;)
z0n3
Started blacking out the badging. Did the two easier ones. Tailgate emblem and the front grille letters. Tailgate is easy if you pop the tailgate panel off the get the two upper clips loose. 7BDC4FA6-07E1-47C4-AE22-924EEA471782.jpeg
davidn0021
SoCal
Was finally able to put my Lomax Cover back on! Had to modify the rails by cutting them a little bit, but they're still fairly solid and stiff! Also added extra weather stripping because I can see where water will leak in, and will probably have to add more as there is still a little bit of a seam in certain parts at the front of the bed.
EJ84
That is the cover I am looking at, are you saying you had to cut the rails on the cover or the rails on the bed utility group? Also I am looking for a waterproof cover do you think this will let a lot of water in?
Thanks,
  • Nels
