DONZILLA
I know you were asking the OP about the mopar deflectors but figured I'd come in that I have the EGR in channel and they've been flawless for 1 year 8 months. They are about $90 a set I believe.
Thanks! I remember looking at those. Kinda thin I thought.
millerbjm
St. Paul, MN
Mine are actually very thick and the cust service was very good. The 1st set I received had a very small defect on the rear passenger side and when I asked them over email they immediately sent a new full set no questions asked and no cost to me.
Chopperbobby
installed OEM rain window deflectors. Easy install except the pins. Still easy. Just thick fingers made it a little more challenging. Love the ram emblem on the front door deflectors.
z0n3
Ordered the last of the black badging... laramie badge and the sport hood bezel.
Funeman
Installed block heater cable. Noco weather proof outlet protector going in under the bumper once I get the 2” hole cutter. No more sitting in an ice box in the morning.
Grouper
Sheesh that’s a lot of clips. You’re right those are some serious clips too.. I have heard someone pulled their heat shield from the hood and only 4 of those clips were accessible underneath.. you’ll have to update on when you install this, curious to see which route you take.
I decided to go all in. I pried-off the the old bezel and I'm glad I did. I didn't want to hack-up the brand new bezel by attempting to remove only the emblem. It wasn't very difficult. The hood is some kind of plastic, so it's pretty forgiving.
The OE black looks so much better than the chrome with the overlay, in my opinion.
You can find some more pics by following this link.
Before, with overlay applied to chrome emblem:
After, with entire bezel replaced with OE black emblem:
z0n3
Looks much better, I ordered the full bezel and will do the same as you. Nice work!
Ram Man 727
Ontario, Canada
The Noco outlet works great. I put mine just to the left of the rear license plate - looks factory installed
flyfingers
Central Coast, CA.
Didn't do anything super exciting or difficult but I did add a bit of practicality by putting in an under seat storage bin. Fits like a glove and although kind of pricey for a simple piece of molded plastic, it's invaluable in terms of additional storage.
On Amazon - Husky Liners - 9421
WReckeR
Indianapolis
I bet it saves tires more than fuel. Ha!
Actually, I've been debating if overcoming the throttle lag would actually help me save fuel because I currently push harder because I know I need to just to get going. Then, I get too far into the throttle and next thing I know, I am at 4k RPMs when I was only trying to add a little bit of speed quickly. This is especially true when trying to overcome the drops in speed when going up overpasses (not many hills in Florida) on the highway. I also have the 3.21 gears, so it's not as responsive.
Man, what a mess! I'm gonna pay for a truck this expensive, and it's lethargic and complains uphill? Sheesh.
WReckeR
Indianapolis
Ceramic coating, love how it makes the paint look like glass
DIY, or professional? Pro grade is a much higher quality product, supposedly. It looks great. Granite Crystal?
Jako
Borough of Parks
How was the install? Where did you run the wire if you are using the Noco?
spencerclift21
Professional, I’m going to have the truck for a long time. Granite Crystal looks phenomenal with the ceramic coating.
I went with professional because I just have to take it back once a year for an inspection and they will fix any imperfections with the coating thanks to the warranty.
Vinnie.
Chicago Suburbs
dang that sounds awesome. what state/ shop is that?
Funeman
Hardest part was plugging in the wire. I was just barely able to reach it over the tire in the wheel well. I ran the extension cord along the passenger side of the engine compartment to the front and straight down to the inside of the bumper. I zip tied it in a few locations along the way. Heading to Harbor Freight tomorrow to get the hole saw blade. Noco install will only take 5 minutes.
Jako
Borough of Parks
Did you need to remove the starter? That is what it looks like from a You Tube video. Dealer wanted $545 for parts and labor - no tax:eek:.
