Tat2GirlAz
Thanks saved me from ordering a set off the amazon
EGR fender flares are available now. Just saw a listing on ebay for the 2019s.
No problem. I won't be ordering mine just yet but I will be getting some.I actually like their design, thanks for the heads up. You rock !
I got a reply from a online Mopar parts seller. Attached is the parts diagram for the fender flares.
From what I gathered from the diagram the below is needed.
6FX92TZZAB Rear Right
6FX93TZZAB Front Right
6FX90TZZAB Front Right
6FX91TZZAB Front Left
68349566AB Spat Front Right
68349567AB Spat Front Left
68307196AA Spat Rear Right
68307197AA Spat Rear Left
Are these the correct part numbers by chance, I have been looking everywhere to buy the flares? Also, where did you end up purchasing them from and how did the tape work out over the clips?
I was just looking under my truck and noticed this. Seems like they went to a more permanent mount possibly to get rid of the tape issues from pulling away. If you cut the nuns flush and use a high quality 3m tape, it should work fineWell I got the first fender flare so far and it wasn't what I was expecting. Apparently the fenders have holes drilled in them for the factory fender flares, I was expecting double sided tape like they use to use. I will probably remove all those clips and get some double sided tape to attach them.
I put a couple pics of my truck here, https://5thgenrams.com/community/threads/bighorn-quad-cab.2411/Looking forward to pictures of the flares on your truck. Good info in this thread.
Just adding my $0.02. Ordered OEM flares from the dealer, having them paint, then mount for around $600
