Fender Flares
banditsc
Does anyone have access to the parts diagrams? I'm trying to find the part numbers for the fender flares and mounting hardware that is used on the Laramie and up. I ordered a Bighorn which doesn't have them, even with the Off Road Package. Would like to add them on and will most likely do the factory two tone to it, so will need them. It doesn't appear any of the online Mopar parts dealers have the 19's up yet.
I don't believe the factory two tone is available with the Bighorn. You'll need to move up to the Laramie.
Correct, I plan to have it painted after it arrives. I didn't want the leather in the Laramie. So I need to get the fender flares from the Laramie and above.
Guessing nobody has access to the parts lists yet? Wish the online Mopar parts sites had the 2019s up there.
I got a reply from a online Mopar parts seller. Attached is the parts diagram for the fender flares.
From what I gathered from the diagram the below is needed.
6FX92TZZAB Rear Right
6FX93TZZAB Front Right
6FX90TZZAB Front Right
6FX91TZZAB Front Left
68349566AB Spat Front Right
68349567AB Spat Front Left
68307196AA Spat Rear Right
68307197AA Spat Rear Left
Well I got the first fender flare so far and it wasn't what I was expecting. Apparently the fenders have holes drilled in them for the factory fender flares, I was expecting double sided tape like they use to use. I will probably remove all those clips and get some double sided tape to attach them.
^^^Are those flares in primer color On the outside?
Black plastic.
My plan was to two tone the truck. But after putting the black fender flares up against the Delmonico red and with some black running boards, I think it will look pretty good with out paint.
Black plastic.
Cool! I'd like to see that! I have painted flares but like how the Rebel looks with the black flares.
Here is one with just me holding it up.
  • Like
Reactions: Taz
I think this will save me from painting. Only have one flare so far, waiting on the rest and need to order the running boards.
Maybe they did away with the 2 way tape cause my 2014 the tape keeps letting go(factory tape) and I have to stick them back on with some good(3M) tape.
^^^. Now that part I agree with as my friends with flares were stressing over that with their 4th gens.
I am hoping to get the last three this week, so plan to do it this week. No clips needed if your truck didn't come with fender flares. You would be removing the clips from the fender flares and using some double sided tape instead.
I found the spats on the back of the wheel opening are different for the fender flare trucks, so those also need to be replaced. I added them to the list, they are only like $5 a piece.
They actually appear to be different, I thought they initially were the same, will remove that reference.
