Granite crystal metallic thread
d15nonvtec
2021 Limited Night Edition
Wheels from my 2019 Laramie going on this one in the spring
Grey Goose
I had a 2019 Bighorn/Lonestar also for less than a year paid it off then got a 2020 Laramie
kooz21
I’m perfectly fine with the Diamond Black I have on order... buuut I just saw the granite for the first time. Damn! If I woulda seen that first...
JbVt
Just saw this thread, thought I’d throw mine up here.
Here’s my ram after waiting 14 weeks to get my king shocks! It was defiantly worth the wait a day after I got them in I installed them my self and hit the dunes in Oceano CA.
Gitter
Texas
I can't believe I haven't posted in here yet cause I love this color! It's dark enough that it looks tough, doesn't show dirt as easily as darker colors do, and it can really pop when in direct sunlight when it's clean!
Here's mine as we were heading back home over the Holidays (a 1400 mile round trip with a few stops over 2 weeks)...hard to see how dirty it really was after going through a few storms.
Nels
Wisconsin
Looks great! How long is your TT, around 23? Are you using a WDH? My TT only 19 (rated) 4400 lbs and sags my truck a lot. Planning a WDH next season. Also still trying to decide on tire size after a Readylift 2" level. Still running the stock tires but they're tiny. How do you like the combo of 295/60 while also pulling a trailer? I have 3.21 gears so my experience may be different from yours.
Gitter
Texas
Thanks! It's a 25' trailer (29' when you include the tongue) with a dry weight of over 5,822lbs and I do have a WDH/swaybar combo system...it's a must for a trailer that long with a 1/2 ton! I do have the stock (for Limiteds) airbag suspension which levels itself after the trailer is on the ball.
I love the tires! Not only do they look beefy, they are just as quiet as the stock tires and they handle great. Of course, being E-rated, they are a little stiffer, which helps with the minor sway I would feel when it was windy or when passing big rigs. Now I only feel some swaying during high winds.
Once your at freeway speeds, there won't be much different between the 3.21 and the 3.92 since both won't be using overdrive when towing. The 3.92 really shines when starting or at lower speeds tho.
Of course, my tires and the 3.92 both take a couple MPGs away from my daily commute...but the smiles per mile make it worth it. :)
  • Site Vendors
