Fehrman627
Not much done to it besides GoRhino RB10 running boards put on and Truxedo TruXport ordered to put on.
2019 Ram Laramie Granite Crystal with KMC XD 20” wheels on 12.5x33’s Toyo Open Country Extreme A/T 2.
Today changed Engine oil to Amsoil XL 5w-20 and filter. Rear Differential to Amsoil 75w-90
securityguy
North Florida
Nice wheels and tires!
Gandalfgrey
LaPorte, Texas
Today I painted my tow hooks B-5 blue & my rear shackle also, then UPS showed up with my Mcguard black lug nuts so installed them.
grimreefer
U.S. Merchant Marine
Free State of Florida
Oil/filter change and an alignment. A hair over 3000 miles and I noticed the front tires were starting to wear on the outer edges. Toe in was off a good bit... I suspect from it's trip from the factory to Florida.
MayhemMOORE
Installed the Mopar tri-fold hard tonneau. Pretty simple install and happy with the look. Couple spots the rubber seal is wavy but I’m hoping some sun and the heat in the garage will help that work itself out.
Also pulled the radio and pinned the connector to run a front cam with the “cargo cam” soft key. Ran into some confusion with wiring but another member helped me get it squared away since the ‘21 had some wires I wasn’t expecting. Haven’t been able to test it yet since the nav radio is going to need to sit for the key to show up again, but if it works on my test, I’ll go ahead and install the camera in the grill tomorrow.
Gandalfgrey
LaPorte, Texas
Very nice. Was it difficult to get the tow hooks out and back in?
No not really lots of room behind the bumper & you need to know the back bolt that’s over 6” long only has an inch and a half of thread but has a keeper washer so once you screw it down until it stops place a wrench on the head & beat it out. You won’t need that little washer to install back. It’s just to make factory ensembly easier .
406Rebel
I like it. Did you use reflective concepts for covering the badging or something else?
Le_Slacker
London, Ontario
Added a pair of Toyota cleats tot he utility rail
Fits perfectly, and is somewhat larger
z0n3
Thanx - I looked that up, I'm just anal retentive on stuff like this as I don't like the light on my dash. :>)
Any chance you have modified or added anything to the air intake system? I got this code when I added my SB intake on my 2019 and it went away after unhooking battery for a while.
