LED Reverse Lights
Jako
Borough of Parks
Thanks Jako, your install is what inspired me to do it. That was a great write up!
Thanks for the thanks. Lot of good people on the forum sharing their knowledge and info (VLEDS, Kafeek, SMD, Baja) that helped and encouraged. I think most people can handle the install. Not too bad of an install if you have "things" in hand. I took my time "assembling", sometimes the journey is more important than the destination.
The SQRs look sharp, nice lenses. Looking forward to your "What I did to my Ram today".
MValdez
North Wales, Pa
Somehow I missed this post. Did you get your custom light show configured using your computer attached to the Tazer? There is a software on their website that you can download and then use to configure your Tazer DT while it is out of the truck connected via USB to your computer and you can also update the Tazer Software if you don't have the latest version.
OH see I did not know that. I never use the light show feature and really only wanted to customize all my lights to flash as 4 ways for safety reasons when at events for my business. Thank you for replying I will download the software for the Tazer site today.
JJRamTX
Colorado and Texas.
Wanting to pull trigger on some lights are theses Walmart ones worth the price??? And how are they holding up?
I got the same Nilights off Amazon and they are working fine but the one on the right has gotten some moisture in it. It looks like I can open it from the side and wipe out the moisture and then seal it back up.
kittyjo
Ya I had mine for a while now no problems. So bright at night people flash their brights . Can see for at least a hundred yards in pitch black.
Jakecukich
So using the curt connector, if I go to plug in my jet ski trailer.. is everything still going to work?
brawler1588
Yes the curt adapter plugs into the rear behind the bumper and just gives you an extra wiring harness to play with so you don't have to touch factory wires.
Chopemupgood
So is there really a need for the splitter if you can just wire it into the reverse light and if that's possible what do I do with the other wire on the light? Is that just a wire to connect to the chassis for a ground?
Jako
Borough of Parks
You can do it that way. I think members go the harness route for warranty and reliability. Yes, ground.
Chopemupgood
Thanks, Saturday job is confirmed!! That and Tonneau cover all in the same chore and I will be 1/90th of the way to completion. lol
Jako
Borough of Parks
Here is the site for "Ram Crack":
Once you get started it may be hard to kick the addiction.
Ever_Garza
Can someone help. I ordered these two parts. Are the pigtails correct? Or did I get the wrong one?
Jako
Borough of Parks
I am not sure what you are trying to do but here is a lot of information and options on reverse lights.
Ever_Garza
Mounting in the bottom bumper and using a plug n play kit while splicing into that harness so I don’t have to splice into the factory wires. I looked through those and I couldn’t find what I once found lol. Just want to see if anyone can chime and see if I can use the harness to plug into the back of the bumper with this.
Let me try looking again
