Neurobit
RAM Sorcerer
Is that ”what she said”..?Anyone know if it is possible to upgrade from the 5 inch to the 8.4 inch system?
I have this one for sale but it comes with steering wheel heating and seatsI just purchased a 2019 RAM 2500 tradesman 6.7L 4x4. It has the 5.0 and I almost went with the infotainment $1700 swap until I found this thread. Excellent works guys.
I have the part numbers for the RA4 UAS radio (68428584AC) and the instrument panel (6VQ511AHAA) but the part number given for the CenterStack bezel (68340283AD)in this thread won't work for me. My traction control button AND Hazard lights are grouped together. I've spent 4-6 hours looking at Mopar PArts sites and cant find anything.
Does any one have the part number for the bezel shown below. No heated seats, not dual climate. I just need my hazards and traction control buttons. Thanks in advanceView attachment 78037
Were you able to get the Bezel with the traction control and Hazard buttons? Like this? If so do you have the part number? I've searched for days and can't seem to find this bezel. I've come close but they seem to have the seat and steeering wheel warmer controls too. I don't need any of that.Do you actually have the real part number from this particular bezel. I need this very one with the split button for hazard lights and cannot find it anywhere. Tia!
I may be interestedbut i'd rather have one without having to explain to people why the heated seat buttons don't work. Also is that a lane departure on/off button or a traction control button?I have this one for sale but it comes with steering wheel heating and seatsView attachment 78103
Here’s the VIN of a truck equipped with the bezel you’re looking for- 3C6UR5CL5LG286932Were you able to get the Bezel with the traction control and Hazard buttons? line this? if so do you have the part number. Ive searched for days and cant seem to fins this bezel. I've come close but they seem to have the seat and steeering wheel warmer controls too. I don't need any of that.
Probably I don't even knowI may be interestedbut i'd rather have one without having to explain to people why the heated seat buttons don't work. Also is that a lane departure on/off button or a traction control button?
Thank you. My local Dealership says it part # 68370124AB. The online pics make it look like it just has the single hazad button but maybe those are just generic pics. I'll get one ordered and see if its right.Here’s the VIN of a truck equipped with the bezel you’re looking for- 3C6UR5CL5LG286932
You can call any parts department and give them that VIN, and ask them what part number lower center stack that truck uses.
That’s the lane-departure enable/disable button.I may be interestedbut i'd rather have one without having to explain to people why the heated seat buttons don't work. Also is that a lane departure on/off button or a traction control button?
Hi Jimmy07, do you think itll be possible to drill new holes in the center dash piece so you can mount the radio bezel?I’m not installing one of these.
On another note, here’s why the center dash can’t be reused. The radio bezel locating tabs and mounts are different. This is from member kristof-![]()
Hey there I’m going to do the same thing to my 2021 rebel. I just want to make sure on a couple things. I know it’s plug and play. But did you have to have the dealer do anything like flash it or give a key code. Or did it work once all connected?Good evening all,
First, thank you to everyone who contributed here.
I have been able to successfully upgrade my stock 5 inch radio & standard AC controls for the 8.4 without Nav (everything working) with the following parts:
8.4 screen no Nav: P68292209AF (VP2 8.4 DT SXM)
Center black Bezel with regular AC controls and knobs for 8.4 screen: 68340283AC
Center Main Console with AC vents: 5YU433XLAD
View attachment 59155View attachment 59166View attachment 59167View attachment 59168View attachment 59169View attachment 59170View attachment 59219
If the radio is used then you will need a code to unlock which you can get online. You will have to replace both inner and outer bezels to fit the new 8.4 screen. Make sure you match the correct center bezel since there are multiple configurations. I haven’t been able to verify if a new radio would work without any dealer programming but other members have done used ones without an issue. Just need the donor vin to get the unlock code. I ended up ordering a used radio with both matching bezels for my tradesman that I should be able to install next week. Prices have been going up in the last month both online and at junkyards from wrecks. They were like $600 and now start at $1k to $1700 from infotainment. You can buy all new parts online for approx $1200 (radio, both bezels, bracket and screws) but like I said unfortunately haven’t been able to verify if a dealer programming is needed.Hey there I’m going to do the same thing to my 2021 rebel. I just want to make sure on a couple things. I know it’s plug and play. But did you have to have the dealer do anything like flash it or give a key code. Or did it work once all connected?
Thanks for posting. Nice to know after being told by multiple dealer parts people it prolly won’t work. Approximately how much were all the parts new? CarPlay, compass, camera all 100%?I have a 2020 Ram 1500 Bighorn and purchased new both bezels and the 8.4 radio. It was plug and play, there was no code to enter for the new radio. No issues since install.
I did purchase the Sirius XM cable and antenna from Infotainment for the install.
Thank you to all in this forum for the needed part numbers and help for the install!
What center stack do you have and is it the non Navi display?Radio and bezels plus shipping was around $1400.00. Sirius XM antenna and cable $70.00.
Have to unplug phone and plug back in after shutting off truck sometimes to get Carplay to connect.
No issues with Compass or back up camera. Can also select camera when not in reverse. Navigation is great using Google Maps.
There was no Dealer programming Required.
Manual A/C controls.What center stack do you have and is it the non Navi display?
this one?
what are part numbers for the display and the center stack? I’m looking the a non navi too so I can just plug and play.
