Chippewa
- Jan 13, 2020
Just wondering to verify output. Does this wire only supply brake light? Or does it supply running light and brighter brake light. An if needing to run wires back from switches anyhow would it be possible to clip in to source side of pin26? Thanks for sharing so much already.The pin is brake. I have confirmed it functions correctly. Next will be to buy a pin kit, female side and then run the wire to the rear of the truck. Cavity is empty on the under harness side.
