Tire fill assist
edrclark
Moderator
Site Supporter & Order Tracking
Portland, Oregon
I have never actually used this feature myself, but a search of the owners manual says this
The customer may choose to disable or enable the Tire Fill Alert feature through use of the customer settings in the radio. NOTE: • Only one tire can be filledata time when using the Tire Fill Alert system. • The Tire Fill Alert feature cannot be entered if an existing TPM system fault is set to “active” or if the system is in deactivation mode (if equipped). The system will be activated when there is over 1.5 psi (10 kPa) of change in tire pressure. The ignition must be in the RUN mode, with the transmission in PARK (P). NOTE: It is not required to have the engine running to enter Tire Fill Alert mode. The hazard lamps will come on to confirm the vehicle is in Tire Fill Alert mode. When Tire Fill Alert Mode is entered, the tire pressure display screen will be displayed in the instrument cluster.
PowerJrod
Las Vegas NV
Weird... So I guess mine just doesn't work or it's calibrated for max tire pressure.
Maybe I should try to put in more air than the door sticker says and see what happens. The warning light for low pressure comes on at 27psi and turns off above 28psi, but even up to 35psi, no horn or lights.
Richard320
I found it to be sluggish unless the truck was moved a little, enough to awaken the TPMS and have the pressures change from where they were when shut off to where they are now. For me, that's less than a block.
PowerJrod
Las Vegas NV
I've gotten to 38 psi with no warning, that's why Im thinking it won't chime until I get closer to 45 psi.
KiloFive
Vancouver, BC
I went from 22” rims to 18” Rebel wheels... is there anyway to alter the system’s “set” pressures for the higher PSI tires?
Current tires are about 50 psi vs the previous 36 psi.
Thanks!
RJS
Might be simpler to just use an old fashioned tire pressure gauge, that is what I do.
Actually it's not easier with a quage but probably more accurate. I used the system last week as the cold weather turned on my light. Added air until the horn beeped on all tires and checked them. 38 psi all the way around. Close enough.
